PROBLEM WITH MY SCREEN ON MODEL MW27H62
ON MY TELEVISION SCREEN IT SEEMS EVERYTIME WE CHANGE TO ANOTHER CHANNEL IT SHOWS A BLACK SCREEN IN THE MIDDLE OF THE TELEVISION BUT AT THE SAME TIME WE CAN SEE PICTURES ON THE SIDE, BUT EVERTIME TO REMOVE THE BLACK SCREEN IN THE MIDDLE WE HAVE TO HIT DISPLAY, THIS IS EVEN ON THE SHOWS THAT WE HAVE RECORDED. I  HAVE NEVER HAD THIS PROBLEM BEFORE, MAYBE WE HIT A BUTTON WHEN WE WERE TAKING A NAP AND DID NOT REALIZE THIS.
NORMALLY WE TURN THE TELEVISION OFF BUT THIS TIME WE LEFT IT ON.
YOUR HELP IS APPRECIATED. OUR TELEVISION IS A COMBO VIDEO CASSETTE RECORDER AND DVD VIDEO PLAYER.
  I HOPE YOU CAN HELP US CLEAR THIS BLACK SCREEN IN THE MIDDLE.
                                             PEARL RODRIGUEZ
Posted by PERLITA on
  • mdevans18 Jun 18, 2008
    We have the exact same problem with out Toshiba video/DVD/TV. The black screen takes up 80% of the screen. The audio is still there and you can view around the perimeter of the screen. Any suggestions/ Thanks
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Picture Problem
Some how or some one switched on the closed caption feature in the set as thats a text box.. your going to need the original remote to turn off the closed caption.
Posted on Sep 28, 2006
Anonymous
  • 3130 Answers
SOURCE: Changing the Recording speed from SP to EP on TV/VCR Combo using universal remote?
I am sorry to have to tell you this, but the only way to change the recording speed is with an original remote. If you look on the original replacement remote link I posted here you will see the SP/EP selector, this is to change the recording speed. Good Luck. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS13TVR90&brand_pn=FISHER_DS13TVR90&mode=large&uid=11755283300930
Posted on Apr 02, 2007
Anonymous
SOURCE: zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton [email protected]
Posted on Nov 02, 2008
Anonymous
SOURCE: Can not capture video or picture
A law suit was filed against Samsung for the SC models including your D23. in accordance with the class action settlement, Samsung has agreed to repair or replace the effected models for zero cost including shipping and insurance. visit this website http://www.samsungclassaction.com/7.html or call Samsung repair @ there 1-800 number. Samsung also agreed to refund your money if you paid to have the unit fixed yourself or if you purchaced another camcorder to replace the faulty samsung. I called and they e-mailed me a UPS label to print out and shipping costed nothing. takes about two weeks for the repair and then it will be delivered @ your door like new:)
Posted on Dec 11, 2008
Anonymous
  • 33 Answers
SOURCE: Trying to help this older
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Posted on Jan 08, 2009
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
There is a black solid square constantly showing up on the middle of my screen. If i change channel and go back it does disappear but then returns a few minutes later
you have close caption on..put cc off.on remote should a button if not .tv menu should have one..but for shure you need to put cc off.
Sep 28, 2010 | Insignia LCDTV26 26 in. Television
Large bluish blub in center of screen.
You have a bad light engine. The part number is UX22201DR if it is only a 50V500 model. If the model is 50V500A or 50V500G then the part number wil change.
Sep 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Tv Problems
Go into your customer menu to closed caption and turn off the "text" mode... What you're seeing is a text box from closed caption but unless you have that additional service it will just me a black square...
Bill
Dec 09, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
