Question about Canon PowerShot S45 Digital Camera
My Canon PowerShot S45 Digital Camera has worked flawlessly until, when recently operating it at the very end of the battery charge (with the low battery icon flashing), it started trying to power down.  Then, as I tried to close the front slide over the lens, it lost power completely and froze with the lens retracted but the cover stuck open.  My fully charged backup battery had no effect, and I have now tried another fully charged battery with no effect.  It is powerless and dead.  Any ideas?  Thanks.
Posted by parson on
  • Ranju A Nov 19, 2007
    This sounds very similar to my situation... no power or life in any mode with any battery that has been recharged. I wish I had a solution to offer. We both may be without a S45 going forward...
Anonymous
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
Posted on Mar 13, 2008
Anonymous
eNDi
My canon powershot s45 does not have a driver for windows 7
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 28, 2011 | Canon PowerShot S45 Digital Camera
MY CAMERA WAS OK BUT NOW IS NOT COMING ON
Is neither the taking pictures or viewing pictures mode working?
If it's only taking pictures that's a problem, make sure you slide the cover all the way across until it clicks. I have the same camera and have noticed it won't come on if you don't push it all the way.
Feb 24, 2010 | Canon PowerShot S45 Digital Camera
I want to charge battery directly from the camera to the computer without the charger . can i do that ? pls help. Thank you
Not without performing major surgery on the camera. As delivered, the camera does not contain any charging circuitry.
Feb 16, 2010 | Canon PowerShot S45 Digital Camera
Battery problem?
i have this excact same camera ... happened to me... it will work after a little bit, open battery door and let sit for 3 days, other wise turn screen off
Oct 21, 2009 | Canon PowerShot A430 Digital Camera
Cannot find a driver for Canon PowerShot S45 for Windows Vista
When connecting a digital camera to your computer with the usb connector, then turning it on the memory card in the camera becomes a removable drive under My Computer and will also bring up a dialogue window that will ask if you want to import pictures, etc. There is no need for a driver. Steve Medley
Dec 11, 2008 | Canon PowerShot S45 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Canon powershot s45
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 06, 2008 | Canon PowerShot S45 Digital Camera
Help!
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2007 | Canon PowerShot S45 Digital Camera
My Sony Cybershot DSC-S45
the button is offset inside the camera, there is a little piece of plastic that seems to loose its elasticity and will not depress the actual on/off switch inside.
Dec 09, 2007 | Canon PowerShot A460 Digital Camera
Canon PowerShot S45 Digital Camera Logo
386 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
