Question about GE Spacemaker JVM1640SJ Microwave Oven
The turntable makes grinding niose when engaged
I replace the platter drive motor but the turntable still makes a grinding noise. If I dis-engage the turntable, the noise is gone.
Model # is VPM1440DB 002
Posted by brighteyes55 on
William Miller
  • GE Master
  • 9,179 Answers
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Posted on Oct 22, 2007
GE advantium 120 convection Cafe microwave making rythmic sound when plugged in and not running. Is coming from the right side of oven Any ideas what it is and how it can be fixed?
The only cause of clunking I can think of is the turntable motor not engaging the drive spindle of the platter properly. Remove the platter and see if the noise goes away.
Nov 03, 2017 | GE Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
The turn table sometimes (most) doesn't turn and stuff like coffee in a take out cup will burn at the bottom
The turntable motors in most units is marginal at best; they are synchronous motors and while reliable, can fail.
Try removing the glass platter and heating a cup of water while watching the center spindle to see if it is turning consistently. If not, it may be defective.
When replacing the glass platter make sure the bearing ring in properly located and that the platter engages as it should.
Jan 24, 2011 | Magic Chef CMV1100 Microwave Oven
Turntable does not turn when on. I've checked the turntable button and it is on.
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site www.partselect.com If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Turntable will not turn with glass turntable on it
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Turntable has topped working.
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpfull, please rate my solution
Apr 24, 2009 | Microwave Ovens
Grinding noise from turning platter mechanism - Kenmore #63252
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave, model # jes738wj02
It's normal for it to rotate in either direction. It has to do with the position of the motor and the instantaneous line polarity at the time the power is engaged.
But the grinding noise may indicate a problem...
You can do a quick check. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours sounds like it's grinding, etc., you may have a bad motor.
To replace it, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 14, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
679 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
