Roku 3 when accessing content displays the folowing error message: HDCP Unauthorized. Content Disabled." Have soft booted, hard booted, powercycled, powercycled TV, re-seated hdmi cable, tried 3 different hdmi cables, am able to get audio and can get video until begin streaming most any channel on the roku 3. Please advise.
Hello... I searched the internet and found this. I hope this helps...
To resolve the "HDCP unauthorized. Content disabled" issue, try these steps:
If the above did not resolve your issue, try these additional suggestions:
Posted on Nov 18, 2017
SOURCE: I installed a Roku 2100-X with a composite video
It seams that it is not supporting well the Hdmi cable ...try to change in a second hdmi channel if it has...also be sure you selected the hdmi on the tv ..and after that from the menu rectify the issues for the image ...first try the auto-setting button ..and if this is not working adjust them one by one horizontal ..and vertical ..and all from the tv settings (osd)
Posted on Jul 21, 2011
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Posted on Dec 10, 2011
SOURCE: my roku will drop the program while watching a movie
Sounds to me that your Roku is losing signal to the Router or hotspot. Try setting the router at least 5 feet away from the Roku Box and the higher the router is in the house, the better signal for all devices. Wi-fi broadcast down easier than up!
Posted on Jan 31, 2012
Jul 06, 2018 | LG Televison & Video
Jul 05, 2018 | Televison & Video
Mar 18, 2018 | Televison & Video
Dec 25, 2017 | Roku Televison & Video
Nov 18, 2017 | Televison & Video
Dec 27, 2016 | Televison & Video
Dec 04, 2016 | Samsung 6030 Series UN40FH6030 40" LED TV...
Jan 04, 2016 | Televison & Video
May 06, 2015 | Roku 3
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
375 people viewed this question
