Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Message alert at top of screen
Phone beeped (not my usual message tone) i now have envelope at top of screen. go to message in box but no new messages !!!!!!!
can you help get rid of icon?
cheers
john
  • onetop Oct 17, 2007
    removed battery (20mins) didn't work tried to reset keeps asking for code!! maybe on box at home but thanks anyway i'll let you know how it goes
    cheers
    onetop
  • 425 Answers
Try resetting your phone to its factory settings. you can find it usually at the setting menu of your phone or else try also removing your battery and put it back again and switch on your phone...
hoep it help you...
Posted on Oct 17, 2007
6ya staff
SOURCE:
How to change message tone on Samsung gt s 3653
Dear,
The msg alert tone depends on the current sound profile of your phone (like normal, silent, driving etc).
1. Go to main menu -> settings -> phone profiles. You should find all the profiles available in the phone. For example, we will change the msg alert tone for 'normal'.
2. Tap on the box with the double arrow (>>) symbol next to normal. You should enter a screen saying call alert type, voice call ringtone etc.
3. There is a drop down menu at the top right side of the screen. Tap that and select 'new messages'.
4. 'message alert type' should be melody or vibration & melody, depending on your preference.
5. now select 'message alert tone'. The phone has a number of tones already stored. Select one of these.
6. Or select 'sounds' at bottom right and browse to any file you want to set as message alert tone instead..
7. Save and exit !!
----pls rate if you find it useful-----
Regards,
Samy
Aug 10, 2014 | T-Mobile Cell Phones
How do i install a new ringtone for incoming messages on a samsung s5600 mobile.
Hi, you have to download new ringtones for you phone by browsing with the phone, downloading and installing the ringtone and you follow the steps below to use your desired ringtone..
  • Go to menu display and light and press for widget.
  • Tick sound settings box and click out to main screen.
  • Pull across the little tap at the side of the screen and press the phone icon.
  • At the top right hand side click the little box and scroll down to New message.
  • You will see a box containing Message alert type and another box with Message alert tone.
  • Just select a tone or go search for one by selecting sounds.
Hope this helps.
Apr 15, 2011 | Samsung S5600 Unlocked Cellphone with...
You can try two different approach to change the message alert tone:
1) Go to menu display and light and press for widget
2) Tick sound settings box and click out to main screen.
3) pull across the little tap at the side of the screen and press the phone icon.
4)At the top right hand side click the little box and scroll down to New message
5) You will see a box containing Message alert type and another box with Message alert tone.
6) Just select a tone or go search for one by selecting sounds.
or
  1. Go to profiles
  2. Select new messages from the drop down list on the top right corner,
  3. Select message alert tone, choose sounds go to gallery and then
  4. select the tone that you want to set as message alert
Feb 25, 2011 | Samsung SGH-S5230 Cell Phone
How to change my message tone to my samsung gt s3653
7. Save and exit !!
Jan 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How to change Message Alert tone
7. Save and exit !!
Jan 05, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How do i change the text message alert?
By alert you mean the Tones of the Incoming Messages:
Go to Menu--Settings--Phone Profiles--Click the Arrow next to the profile you have already been using--on the top You will see an arrow facing download (a drop down menu button)--click--select New Messages--on clicking the Message Alert Tone box you will see loads of tones that you would want to select--in case if you want any song or tone that you have on you mobile to be your default message alert--select "sounds" at the bottom--select the "arrow" on the top go to the directory where you have the tones..select it and "Add" and then click "Save"
Hope it helped...Let me know if there's any problem...
Nov 03, 2009 | Samsung SGH-S5230 Cell Phone
Message icon and alert
you will need to contact your mobile provider and explain it to them and have them correct that on their network.
Sep 19, 2008 | Nokia 6120
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan([email protected])
May 03, 2008 | Nokia 6600
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Recieving sms
You can go into sounds and set alert tone for txt message so it will souns a tone
Jul 17, 2007 | LG Shine KE970 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
