Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
Samsung shr-1040 how can I retrieve what is recorded on this unit. I need to make copies for law inforcement.
Posted by neanie on
Ron G
    Problem Solver:
  • 14 Answers
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
Posted on Oct 28, 2007
  • 1 more comment
  • Ron G
    Ron G Jul 17, 2014
    Been a while since my last post, times change and now what I do is slap in a USB Thumb Drive in the DVR and go to the time I want to capture and save it to the thumb drive and then put the thumb drive in your computer to watch the video. I found saving it to AVI format is better then the H256 compression as it seems hard to get a player to play that format.
  • Ron G
    Ron G Aug 17, 2014
    I also find Snagit to be the best to only capture recorded video and not waste police time by sending or showing them useless footage.
  • Ron G
    Ron G Aug 17, 2014
    http://www.techsmith.com/snagit.html
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
May 18, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
Mode Key + CH 2
default value.
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Playback on Samsung SHR-1040
you need a new hard drive.
Aug 27, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
327 people viewed this question
Top Samsung Home Security Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
