Question about Intertherm P3RA-048K Air Conditioner
Hvac system My air isn't working properly. When I turn it on you can hear the unit out side come on but the air is barely blowing and isn't very cool at all. So I turned the furnace from auto to on, it is blowing now but still isn't cool. Can somebody tell me what my problem may be.
Posted by David Johnson on
Anonymous
Sounds like you have frozen up. Turn your system from cool to off and your fan from auto to on. Let it run for an hour or so. If blowing seems to be normal again, you may have a duct problem, dirty coil problem, or a low on refrigerant problem.
Posted on Oct 20, 2007
Air blowing cool on passenger side warm on driver side how to fix this
sounds like you have a temp door motor problem on the drivers side. the motors seize/stick and have to be replaced.
Aug 09, 2015 | 2005 Buick LeSabre
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
American standard Hvac not working but a/c is working
I'm guessing this is a heat pump? Possibly outdoor board is faulty??? Tstat not setup for heatpump???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 13, 2017 | Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Jun 19, 2011 | Ruud UAMB Air Conditioner
Frigidair HVAC not cooling; Believe its a emergency heat problem
the switch is on your thermostat - look for something that says "system" or "Em heat, heat, off, cool" switch it to "cool" and enjoy. If that doesn't work, call a HVAC service tech. You could have bigger problems than just the system switch. Good luck
Sep 05, 2009 | Frigidaire FAS185N2 Air Conditioner
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Jeep
grand cherokees had a problem with the dual zone...a door in the hvac box breaks...there is a redesigned door assembly....bad news is you most remove the hvac box which requires freon removaal and dash removal
Oct 23, 2008 | 2001 Jeep Grand Cherokee
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
94 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
john h
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
