Question about Netflix
Netflix buffering i have comercial(comcast)internet still netflix buffers, When crackle which is free dosent?.
Posted by michael cannon on
Jafu Bumbalini
  • 9 Answers
The buffering problem could be your internet bandwidth. Crackle content is streamed at a lower resolution than Netflix. Netflix movies are mostly HD which they suggest a bandwidth of 5.0 megabits, as opposed to Crackle's SD movies requiring only 1.5 megabits. Check your bandwidth and see if that's your problem....good luck.
Posted on Dec 24, 2013
Stop buffering
Buffering is due to data transfer rated, it is to slow.
Jul 20, 2018 | Computers & Internet
Hulu and Netflix etc will not stop buffereing every minute or two....
Note that "buffering" occurs when the "stream" (audio and/or video) is not being received as fast as it is being consumed.
Find a "network speed test" web-site, to see if your Internet connection is working properly. Try different Ethernet cables, to ensure that a bad cable is not causing any problems. If you have other computers on your in-house network, turn them off, to see if they have been "heavy" users of your Internet connection.
Mar 06, 2015 | Apple Computers & Internet
Netflix App on a android slow buffering and loading.
go to settings and application manager then clear data of netflix or move the app to SD card
Aug 14, 2014 | Cell Phones
PANDORA WONT STOP BUFFERING ON PHILLIPS 3D BLURAY
buffering is always a problem with the internet connection speed
depending on your carrier and the type of connection usually either broadband or dsl that is your problem contact your provider a or use less internet with other devices when using netflix high bandwidth
Apr 06, 2014 | Philips DVP5990 DVD Player
Having problems steaming netflix through our TV
It could be buffering when it stops playing your video. You dont need a real fast internet connection but it shouldnt be real slow either. Ive noticed that if you get the basic monthly internet its only providing 3 mbps. Which is slow and will cause the video to buffer. Mine is only a step above at about 7 mbps and I have no problems with buffering. Is this is the case just upgrade to a faster speed through your internet carrier.
if so upgrade to a faster speed.Hope this helped.
Mar 27, 2014 | Netflix
Netflix randomly Buffers during a program
Are you you using a wired or wireless connection? It may just a weak signal from your router if you're on a wireless network.
Nov 25, 2013 | Netflix
I have a internet stick on my Samson flat screen tv. added Hughes satalite for good speed. I added an extender also.
Can you run netflix on a computer without buffering? It might be your internet connection. Usually Netflix will lower the quality of the picture to avoid buffering and will increase in quality when the internet picks up. Netflix also uses different software depending wether it's computer (Microsoft silver light), a gaming console, or a smart tv in your case.
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Oct 13, 2013 | Android Apps
Computer buffering
i believe that your internet conection is too slow. There-for the play back speed is going faster than your incomming speed, so you get a lot of buffering. Check into a couple of ways to speed your internet up some. Good luck!!
Jun 13, 2012 | Toshiba Satellite P35-S611 Notebook
I am hooked up wireless to my ps3 but when i try to watch a movie on Netflix it only plays for 30 seconds and buffers, then plays for 30 seconds and buffers. I can put my laptop next to the ps3 and...
First restart the ps3 and try to load the movie again see if that helps or not.
If the Netflix still only loads on your ps3 but keeps on buffering this might be cause by not enough bandwidth allocated for your ps3. Try turning off your computer and all the devices that are connected the internet. Then try again.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Netflix Logo
416 people viewed this question
Top Netflix Computers & Internet Experts
Lawrence Oravetz
Harrie
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
