Exceed-RC 1/10 Scale Exceed-Rc SunFire "Fire Blue" EP Electric Off Road Buggy 4WD Logo
j
jacob sanders Posted on Dec 24, 2013
Rc car running
The rc car runs if you hold it off the ground but when you put it back on the ground it jerks and does'nt run
nobywilliams
Level 1:
  • Contributor 35 Answers
  • Posted on Dec 07, 2014
nobywilliams
Contributor
Level 1:
Answers
35
Questions
0
Helped
8934
Points
82
Have you got a new battery pack, is it getting fully charged, are you using the right charger, is the esc set up properly. How long since you last used the batteries because if you have not used them for a while..more than a few months, each individual cell within your pack could be faulty due to letting them discharge below a given cell voltage. your peak detection charger will charge them up ( maybe ) but get a false peak detection cut off reading and only rapid charge them for part of a charge required on an OK pack. good luck :)
aerosmithrules100
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 01, 2014
aerosmithrules100
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
256
Points
Could be esc or motor it self
I got a 69 chevy c10 the starter wire grounded to the exhaust fixd that then it wuldnt charge so changed the voltage regular then starter & silaniod seems like its holdn a charge but still wo
Hey Steve, if you need a jump to start it then every thing is working except battery holding power try putting battery on a SLOW charge for a day then try again when its running check output of altinator with a fully charged battery it should be 12.5-13.5 volts and rise when you rev motor up ,when you jump it im thinking the battery is very low and the altinator is trying to recharge battery and it cant do that in just a few minutes running time or take it on along ride and watch amp gauge .good luck Steve.
Woody
Causes car jerk
Car needs to warm up properly so that the automatic choke disengages completely,
After allowing the car to run at idle for a minute or two,
Give the accelerator pedal a quick push to about 1/3 throttle,
Idle speed should drop back to normal running speed and the car drive properly
2answers
How to install this kit
Ok you would run your power(red) wire to your car battery ( ). You would run your remote(blue) wire to the remote wire in the back of your headunit. Same with your terminal/ audio wires. Finally you find a good ground for your black(-). Ex. My ground is the bolt to hold my back seats in. You just need it to connect to ur car body.
My mercury montego idels too fast and when you put it into gear it jerks the transmission
This car has an automatically controlled idle speed system, so when you have a problem like this you must have the dealer run what is called an active engine running test, the test puts the engine through the paces and returns data to show possible problems.
Troble with clutch
Its probably the spur gear. I had that happen a lot of times :)
Runs rough when below 35 degrees
YOU MAY HAVE AN ENGINE THERMOSTAT STUCK OPEN AND/OR THE PCM COOLANT TEMP GROUNDED.
2helpful
Debugger detected
Not sure if your problem is solved yet. I have read about this issue being casued by the nero burning software. An uninstall should fix it
I BOUGHT TWO DIFFERENT PROGRAMMABLE THERMOSTATS TO INSTALL IN MY HEAT PUMP SYSTEM, I FOLLOWED THE DIRECTIONS TO A T BUT WHEN I SET IT TO COOL THE UNIT REVERSES AND PRODUCES HEAT WITH BOTH THERMOSTATS. MY...
heat pumps normally have what is called a jumper wire between you R and RC, RC run cooling. You may not have the jumper installed correctly. Instead of RC you may be using RH run heat
1helpful
1999 Olsmobile Alero
sounds like bad clutches in trans...tranny shop needed...takes 4 qts for a filter change and remember to check it when the vehicle is warm and in park running.
Top Exceed-RC Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
