Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart grind and brew grinds grounds and does not brew coffee
The coffee maker grinds beans but does not circulate water into carafe. tried cleaning water reservoir no prevail..only 6 months old..too expensive of a machine to just throw away
Posted by grant seftel on
Vitally Alcher
  • 1,645 Answers
Go back to store under waranty for one year
Posted on Dec 29, 2013
4 Related Answers
Anonymous
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Posted on Dec 17, 2008
co7196
Ned C Cook
  • 3433 Answers
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
Posted on Sep 24, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
What causes my Cuisinart Grind & Brew coffee maker to spray ground coffee to areas outside the chute into the filter?
I'm glad u were able to find the problem. Hopefully it's still under warranty and you can get a replacement. Well, happy brewing! :) & Hagd too!
Feb 20, 2017 | Cuisinart Coffee Makers & Espresso...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew DGB-600 fills up water in goldtone filter;
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
1,263 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Charles Tidwell
Ekse
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
