Question about Pioneer AVIC-D3 Car DVD Player
Improper connection to park brake lead - Pioneer AVIC-D3 Car DVD Player
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
Rear brakes
Removal
1.Remove rear wheel and tire assembly from vehicle.
2.Remove rear brake drums from hub and bearing assemblies after loosening the two brake drum screws.
3.Be sure that the parking brake pedal is in the release(most upward) position.
4.Completely loosen square nut of the rear parking brake cable. Then create slack in the rear parking brake cables.
5.Remove adjuster spring from adjust lever and brake shoe.
6.Remove adjust lever and turn the adjusting wheel of adjuster assembly to the direction of the arrow as shown.
7.Remove the strut spring and the lower retracting spring from the brake shoe.
8.Remove the upper return spring from the brake shoe.
9.Remove brake back plate hold down spring and pin from the leading brake shoe assembly.
10.Remove the leading brake shoe. Then remove the adjuster assembly, strut and anchor spring from the trailing brake shoe.
11.Remove the trailing brake shoe from the brake back plate after removing hold down spring and pin.
12.Remove the trailing brake shoe from the rear parking cable.
13.Remove parking pivot lever from the leading brake shoe.
Replacement
1.Lubricate the eight shoe contact areas on the back plate and anchor.
2.Install the trailing brake shoe to the rear parking cable.
3.Install trailing brake shoe on brake back plate and install the trailing brake shoe hold down spring and pin on the brake shoe.
4.Tighten the square nut of rear parking cable.
5.Install the anchor spring then install adjuster assembly, and strut.
6.Install leading brake shoe on brake back plate.
7.Install the brake shoe upper return spring, strut spring and the lower retracting spring to the brake shoe.
8.Properly rotate the adjusting wheel of adjuster assembly to the direction of the arrow in as shown.
9.Install the adjuster spring on the adjust lever and leading brake shoe assembly.
10.Install the leading brake shoe hold down spring and pin on the brake shoe.
11.Adjust brake shoes assemblies so as not to interfere with brake drum installation.
12.Install the rear brake drums on the hubs.
13.Check and adjust whether the pedal stroke in the specification.(Refer to section BR Gr./On-vehicle service/Pedal stroke of parking brake)
14.Install wheel and tire.
15.Push the parking brake pedal to the floor once and release pedal. This will automatically remove the slack from and correctly adjust the parking brake cables.
16.Test the vehiche on the road. The adjust will continue the brake adjustment during the road test of vehicle.
Inspection
1.Inspect the disassembled parts for wear, rust or damage.
2.Measure the thickness of brake shoe lining.
Standard : 0.17 in (4.5 mm)
Minimum : 0.04 in (1 mm)
3.If the shoe lining is less than minimum or shows signs of uneven wear, replace new one.
4.Measure the inside diameter of the brake drum.
Standard : 10 in (254 mm)
Maximum : 10.07 in (256 mm)
5.If the inside diameter of the brake drum is more than maximum or shows signs of uneven wear, replace new one.
6.Inspect the lining and drum for proper contact. If the contact condition is improper, repair it with a grinder or replace the brake shoe assembly.
Aug 14, 2013 | 2002 Kia Sedona
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Dual xdvd700
This unit is designed so that it may be operated only when the vehicle is in “Park” and the
parking brake is fully engaged. To this end, this unit includes a parking brake lock-out
feature which prohibits the unit from operating if the vehicle is not in “Park” and/or the
parking brake is not fully engaged. When installing this unit, the installer must connect
the parking brake detect wire (“Yellow-Blue Lead”) to the parking brake mechanism in
order to make the parking brake lock-out feature operable. DO NOT simply ground the
parking brake detect wire to a metal portion of the vehicle. Failure to properly install
the parking brake lock-out feature could lead to driver distraction which could result in
serious injury or death to the driver’s occupants or persons outside the vehicle and/or
property damage.
Once the parking brake lock-out feature is installed, the owner/user must not attempt to
disrupt/neutralize the parking brake lock-out feature by (a) partially engaging the parking
brake and/or (b) purchasing/using any device or unit designed to send necessary brake
signals to the unit. Failure to follow these instructions could lead to driver distraction
which could result in serious injury or death to the driver’s occupants or persons outside
the vehicle and/or property damage.
you could just earth the system straight to the veihicle, which will then dissengage the play in park feature, here is the website for the online manual
http://www.dualav.com/support/manuals/xdvd700.pdf
Mar 16, 2010 | Car Audio & Video
When brakes are applied parking and dash board lights come on.when headlights are on,brake lights and tail lights do not work.very first symptom was an intermittent tail or brake light out indicator...
you might have an open ground wire on your brake/tail lights .. when you apply the brakes then power would flow thru the brake light (not see ground) so would then provide power backwards thru the parking light (common ground open) to all the other things connected to the parking lights .. like the other parking lights and dash ... when you turn power on to those things (headlights on) then there is 12 volts on both sides of the light .. thats why the lights quit working ... if the missing ground is the problem then most of the lights that are improperly turning on should be at a lowered brightness level.. interesting problem .. its also possible to have a brake light bulb that has the common ground open inside or not making connection with its socket .. i would start by removing the brake lamps and see if the problem goes away .. if it does look for a broken ground or damaged lamp ..
Oct 12, 2009 | 1994 Honda Accord
I need precise information on connecting the parking brake wire on the clarion vx409. Do i connect it to the parking brake button or do i connect it to the light on the instrument pannel / dash. Also what'...
Connect your parking brake wire to the ground side of the parking brake switch above the pedal, or at the parking brake lever. As for the the illumination wire, if the wiring harness on the factory side does not have illumination wire, ignore it. It is only used to dim the screen when you turn you lights on. If you really want the feature and do not have the lead on your factory harness. Run it to the headlight switch and connect it to the positive lead
Aug 28, 2009 | Car Audio & Video
Parking brake adjustment
Go back and recheck your work. The cable on one or both sides might be installed improperly.
May 06, 2009 | 1996 Dodge Grand Caravan
How To Bypass The Brake Switch To Watch Videos While Driving?
Clarify please-does the screen show "Audio Only" when a DVD is inserted? If so, this is because the parking brake lead is not set up to work. Normally, the green lead connects to the parking brake negative on the car. This means you don't get video unless the parking brake is set. To bypass this, you need to wire the green parking brake lead to one terminal on a toggle switch, then you run a wire from the radio ground lead to the other terminal. toggle the switch up and down and you should have video. You can get a pretty small toggle switch and mount it in a concealed place.
This is by no means advocating watching video while driving!!!!
Apr 12, 2008 | Clarion (VRX765VD) Car DVD Player
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
Pioneer AVIC-D3 Car DVD Player Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
