Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
Reset dap 1322
How to reset a dap 1322 to factory settings?
1 Related Answer
Anonymous
  • 11 Answers
SOURCE: i can't find ip adress
The device communicates with the computer devices least displaying details. For example, setting up the router modems requires connections also from where the computer adminstrator sets the passes least disclosing detail IP addresses.
Posted on Apr 04, 2011
How to configure dlink dap 1160
Ashraf, you could contact the manufacturer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
DAP 1160 Wireless Access Point
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201160/Manual/DAP_1160_B1_Manual_v2_00_EN.pdf
How to factory reset your Link router
May 06, 2016 | AccessData Password Recovery Tool Kit (ftk...
How to change password?
If you can't remember the password, follow these directions to reset the access point to factory default. You can then log in with a username of admin and a blank password.
DAP 1360 Wifi Access Point Hard Reset PCingredient
If you know the current password, just log in and change it on this page
http://www.support.dlink.com/emulators/dap1360/101/tools_admin.htm
Nov 09, 2015 | D-Link DAP-1360 Wireless-N Range Extender...
If you have forgotten this password, you will have no choice but to reset the router to factory defaults.
Reset Procedure: With the router powered on, Press and hold the reset button (on the back of the router) for 10 seconds and release. The lights on the front of the router should all flash and reboot.)-
Mar 10, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Reset a D-Link DAP 3690
There should be a little button on the back to reset to factory defaults. Sometimes it's hidden behind a little hole and you have to poke the tip of a pen in it, hold it for a count of 5, and all the lights will blink and it will be reset to factory-new.
Jan 06, 2014 | D-Link Network DAP-3690 AirPremier N Dual...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I have DAP-1160 wireless G access point. My pc won't rekognize it. it worked befor reseting, after that the STATUS led does not blink.Not even when it's connected to the pc. What is the problem?...
I had the same problem with a DLINK DAP-1160, it did not seem to reset and I could not connect, nor PING it. It turned out that the box WAS resetting, and although the default IP address 192.168.0.50 and subnet 255.255.255.0 was being set, my computer was assigning itself up a private IP address and subnet 255.255.0.0. In the manual, it does say that you must be on the same subnet, so I changed my alternate IP address for my ethernet to be static and set the subnet to 255.255.255.0 and everything sprung in to life.
To summarise: make sure the computer you are using to configure the DAP-1160 has its subnet to 255.255.255.0.
May 08, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
I can't find ip adress (192.168.0.50) because i'm not sure to proceed factory reset on DAP-1353
Apr 04, 2011 | D-Link DAP-1353 Wireless N 802.11n...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1522 up as a wireless bridge. My current internet provider is Verizon Fios using their router. Why can't I...
Maybe you have the wrong 192... Go command prompt and type in "ipconfig" without the quotes. scroll up and find the default gateway (default gate way . . . : 192...) and type that in your browser and press enter.
If that doesn't work, go to your network connections and right click on the one that is connected click properties, click on Internet Protocol Version 4, click properties, and make sure all the settings are automatic. Restart computer, repeat first part.
If that doesn't work, reset your router and access point. Than reconnect and repeat first part.
Mar 01, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Apr 25, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
64 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
