I understand that to a point but it shouldnt.... im thinking i havbe it wired wrong.I understand that to a point but it shouldnt.... im thinking i havbe it wired wrong.
You can't post conmments that contain an email address.
If it's atill under warranty, use it! Call their customer service and tell them what's going on, I bet it's under warranty still and if not they're still extremely likely to help you out! But it sounds like it's overheating and cutting off, by it I mean the motor that turns the drum that your clothes/water/etc. are in. When these electric motors overheat they'll turn off automatically as a safety precaution as to avoid damaging the motor permanently. Once it shuts off, sometimes they'll come back on and work for a while and then just overheat again- it's a vicious "cycle"! Sorry for the corny humor but I couldn't resist. This is common amongst other things like vehicles(fuel pumps & ignition modules are famous for this), many electronics including an iPhone shuts down when overheated until it's cooled down enough to operate safely but it'll overheat again- it's a part failing but holding on for dear life and it's fate is certain. It's possible this could be a simple sensor, call the experts at GE Customer Suppourt, they'll help you troubleshot the issue and get it resolved once and for all, best of luck!
It's getting so hot that it's going into thermal protection. Turn down the gains of lighten the speaker load. The more speakers that hook up to it the more power it will put out causing the amp to overheat. Eventually it will burn up some of the output Mosfett Power Transistors.
there is built into every motor an thermister overheat sensor that will automatically shut down a motor when it over heats. Once it cools down the motor will come back on.
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Hi, I found the problem was related to the lamp. Your TV power up but then the lamp would
overheat and automatically shut down (audio and video) resulting in a
dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would
come back on. Then overheat, turn off - recycling "eternally". A new
lamp will solve the problem
You either overloaded the processor or the available RAM. Also with these laptops and high end games...it is very easy to overheat them unless they are on a cooling pad with another external fan blowing cool air over them, without it they will shut down due to thermal overload....this is to keep them from melting something. Try checking with the support driver page for your laptop and see if there is a BIOS update that addresses the algorithym for fan speed, then pull the heat sink from the processor, clean everything up and apply a good thermal paste compound, then blow out all the airvents and make sure there are no restrictions.
Do you mean that it actually over heats and shuts down? If it does then make sure you aren't trying to over drive it or underdrive the impedence. A good suggestion for cooling is get some 1/4" spacers and space the amp up off of the surface you mounted it too. I did it when I had my 2 Memphis M-Class 500Ws and just doing that they were cooler. Also make sure it is not mounted in a restricted air flow spot. If it is put some cooling fans by it to circulate some of the air. Let me know if you need some more help. Good luck.
-Andrew Hawkins
Maybe the cooling system has become blocked up with dust and such? That's what happens with my laptop, I have to take it apart every couple months and clean out the cooling system or it overheats and shuts off.
