Jacuzzi R235-958 Gallery Corner Jetted Bath, Almond Logo
J
Jeff Wolfe Posted on Dec 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water system leak
I have a leak in the pumped water return fitting at the tub. Appears to be a cracked fitting or bad joint. Anyway to replace that? It's all glued in place.
US Parts Center
Level 3:
  • Jacuzzi Master 719 Answers
  • Posted on Jan 16, 2014
US Parts Center
Jacuzzi Master
Level 3:
Answers
719
Questions
0
Helped
284325
Points
1972
The suction cover will come off the wall fitting either by removing the screw(s) or by unthreading counter clockwise.
Once the cover is removed you can then access the wall fitting which sounds to me as if it may be broken. If you remove the wall fitting you need to put a small bead of 100% RTF silicone around the lip of the wall fitting before you thread it back into the fitting behind the tub.
Once you tighten that wall fitting up you can clean up any excess silicone mess with denatured alcohol.
Rod
U S Parts Center
Testimonial: "Rod, Thanks for the advice. I did get the suction cover unsealed from the tub wall, however, it seems that all piping parts are glued together, even the threaded ones. (I've got good plumbing experience, and this piece is visibly glued). I've also checked it with a light and can see now cracks/leaks. What are the chances that it was leaking around the tub wall seal, and if I just use the 100% RTF silicone I can seal it (properly) back into place?"
1 Related Answer
Anonymous
  • 127 Answers
  • Posted on Oct 24, 2009
SOURCE: Jacuzzi Espree with side access pannels leaks.
you can use a scissor cutter or a utility knife and make a nice square cut in the hose. After replacing the nut, hopefully you can find one, you can get a pvc coupling, the hose is the same size as pvc pipe, and use pvc glue to reattach the 2 ends back together. Use Oatey Rain-N-Shine glue....it is in a light blue can and the actual color of the glue is blue.
Testimonial: "thanks, but due to space constraints n the amout of hose attaxhed (3) I will try to use the existing nut by wrapping with a hose clamp to keeping it "
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
tip
The washing machine is leaking all the time?
The possibilities for this problem are mentioned as follows:-- Check the water filling hoses which lets the water inside the washing machine while filling. There are two fill hoses.one for cold water filling or one for hot water filling.if this hoses are worn out or cracked the washer will leak.so both the hoses needs to be checked and replaced. But if the hoses are checked OK then other possibility is the tub seals on the tub.The seal can be seen between the transmission assembly and outer tub assembly of the washing machine. If the tub seal is got loose or worn out it needs to be checked and replaced. But if the tub seals are proper and not worn out then other possibility to check out is the drain pump.Check if the pump is got cracked ,loose or worn out.in case or cracked or worn out it needs replacement but if its loose you can just refit it properly to stop the leaking.But if the pump is not leaking and it looks properly fit then other possibility to check is the outer tub assembly.its made up of plastic and this plastic gets cracked after certain period of time.or if any pointed object/material if remain in the clothes while washing .then due to that pointed object there becomes a hole in the plastic outer tub assembly .This all the possibilities.that has to be checked. This will help.Thanks.
on Mar 18, 2010 • Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
2answers
There is water leaking from the bottom of the washing machine
couple of things to check, one make sure the drain hose is properly attached and no clogging. and also make sure all gakets are in good shape. and not worn out.
Water is leaking out from the bottom
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
1helpful
I'm getting water coming out of the seam on the left side between the top of the washer and the side panel. Is this hard or expensive to repair?
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
Water drips into tank when no cycle is running
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Maytag Neptune leaks several hrs. AFTER I finish using it.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
if that is checked then ---------------
During fill only
All the time
2helpful
Leaking washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
2helpful
2answers
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
During fill only
All the time
During fill only
All the time
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
