Question about Juicers
Need to find an extractor for my Auto Eject S&W 38 CTG
Posted by Joseph Rios on
WelBilt juice extractor JE 200 owners manual
Thank you, thank you, THANK YOU! I turned my Welbilt JE200 upside down & it easily came apart. Also, for the tiny spaces, never underestimate the power of the 3 best cleaning tools: bamboo skewers, Q-tips & an old toothbrush.
Nov 26, 2012 | Juicers
The entire unit is vibrating so badly that it sounds like a stump grinder.
This is the nature of your machine, it does not eject the pulp, so it will tend to
go out of balance. Stay away from soft stuff like oranges. Watched a guy on
you tube demonstrating an Omega 1000, essentially the same as Acme, and
he had a hard time with the vibration. Nothing softer than apples and try to feed
it continuously (no gaps), slowly and evenly. Good luck.
Apr 22, 2011 | Acme 6001 Juice Extractor
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
How do you use the juice extractor of black and decker i lose the book that tell me now to you it
The Use and Care Manual for your Black & Decker JE 1500 Juice Extractor can be found here:
http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Instruction on how to use your product can be found on page 2. The manual also inlcude an illustration of the assembly.
Nov 29, 2010 | Black & Decker JE 1500 Juice Extractor
Really need a manual for the [email protected] JE1500 manual. Thank you, Norm Metzger
http://useandcaremanuals.com/pdf/JE1500656.pdf
Sorry someone has not responded sooner.
Nov 06, 2010 | Black & Decker JE 1500 Juice Extractor
Manual for the black & decker juicer
It's here. Thanks for using Fixya!
Feb 25, 2010 | Juicers
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
I need manual to learn how to use it my friend gave me juice extractor 6001c but no instructions so I dont know how it works thanks waring commercial juice extractor 6001c model 31je27
If you Google your query you will be able to find the manufacturer, they should be able to help you with a manual for this model. I hope this is of some help.
Nov 05, 2009 | Waring 6001 Commercial Juice Extractor
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
103 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
