Question about Mitsubishi WD-52525 52" Rear Projection HDTV
White dot in the middle of the screen
A white dot appeared in the middle of the screen and now two black dots have appeared. The TV is 4 yrs old and has the orginal light bulb. I turned the set off and unplugged it but it had no effect.
Posted by Robert on
Robert Smith
    Champion:
  • 213 Answers
You have a bad dlp chip hear a link for you so it will help you to unstay.
how the light eng http://www.youtube.com/watch?v=eyAykjZ3zs4
Posted on Dec 24, 2013
5 Related Answers
Jim Krause
  • 1779 Answers
SOURCE: white dots developing
This is indicative of the DLP IC being bad on the Digital Module.
Posted on Jul 15, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Black and white dots have started appearing on
Light Engine is the most common reason for spots.
UED 1-800-648-6657
Encompass Parts Distribution 1-800-638-3328
Posted on Oct 24, 2010
John Riley
  • 441 Answers
SOURCE: Small white dots are showing up on the screen when
The white spots you are seeing are a result of dust or dirt in the light asm. Mits knows about this as a problem. The inside chamber of the tv needs to be cleaned. If your tv is in warranty they will come to your home and fix it. If not it is very easy to damage the tv by trying yourself, start with cleaning out the chamber that the bulb is in, use compressed air to blow out dust and dirt, them on the sides of the tv are round flaps that will need to be removed and this will go into the main mirror chamber, be careful but blow out any dust or dirt you see on the mirror. I would have a repair tech handel this unless you are skilled in this area.
good luck
Posted on Nov 13, 2010
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: Hi I have a Mitsubishi DLP TV WD-65733, and two
icfghost,
Your light engine is failing. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should help you get the parts and remove and replace the bad unit.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 26, 2011
ladywinn
ladywinn
  • 5138 Answers
SOURCE: We are having white dots
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Posted on Jun 27, 2011
Testimonial: "Thank you so much. I will follow up. We love this TV and can't imagine just having to toss it out. I'll let you know how we make out. Gratefully, es"
White snow like dots all over the tv's 61" screen, and it has spread.
Do a search... there are quite a few vids on it...
May 09, 2017 | Televison & Video
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
II have a mitsubishi . Model number 57734 and it is getting white dots on upper Right of the screen . The dots are multiplying by the day . And now tv will not even turn on . Unit is about 4 yrs old .
The dots are most likley the optical Block ( light Engine ). The not powering up issue could be numerous items , have you tried accessing the self diganosis feature with the power indicator blinking an error code?
Jul 21, 2011 | Mitsubishi Televison & Video
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
White dots on samsung S4266w
we have the same problem and now we're not sure what the heck to do. our tv is about 20 months old. i can't believe we have to get it repaired when we never touch it. EVER. now these dots are covering the screen, making it impossible to enjoy watching it. *annoyed*
laurie eller
Oct 22, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
