Question about Sharp AR-407 Copier
AR 122EN ERROR CODE F5-02 - Sharp AR-407 Copier
3 Related Answers
SOURCE: sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Posted on Dec 10, 2009
Anthony Karuku
  • 268 Answers
SOURCE: how to reset sharp ar
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Posted on Jan 23, 2011
Rick Kasper
  • 2072 Answers
SOURCE: HI, my copier AR-122EN is
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Posted on Mar 12, 2011
Get a serial key for a sharp print ar 122en
serial numbers of all Sharp Copiers are located on the rear right-hand side of the copier , on a silver sticker
Feb 23, 2015 | Sharp Office Equipment & Supplies
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
Mar 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to reset sharp ar 122en
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Drivers for sharp AR122en
Hi there, you can get it if you buy a new copier which has inbuilt printer board. If you bought the printer board separately, you can download it from the internet.Please follow these steps:
  1. Go to Google.com and open.
  2. Type free drivers for sharp Ar 122en.
  3. Select your operating system for example Windows xp and click that link on the right.
  4. Enter Code from image as shown and click download file.
  5. You will see 'Click to download sharpar122en570.zip' click it it and a small window will appear and select whether to save or open. A download window will appear and wait till it completes.
  6. You can us or write it to a CD for future use.
All the best.
Nov 16, 2010 | Sharp Office Equipment & Supplies
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp reset developer on ar-122en
Dec 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR-407 Copier Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
