iRiver H10 MP3 Player Logo
A
Anonymous Posted on Dec 23, 2013
WHEN I SWITCH ON MY IRVER H120 IT AUTOMATICALLY SHOWS "0" SONGS OR FOLDERS. WHEN I INSERT THE CHARGER BEFORE TURNING ON, THE PROPER READING OF FOLDERS AND SONGS IS SHOWN
2helpful
My nokia e63 shows "start-up failed contact
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 23E0000B72A30052D437FCB9F02CF8F2EA2E22CE
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading PASUBTOC ...
SIMLOCK PA identifier:
[0] PA_SL2
[1] PA_SL
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D18815
2answers
I couldn't delete song files from T.sonic 850. I connect it to my computer thru USB & when i delete the song files, it get duplicated & appear as 0MB. when i play the player, those songs appeared...
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
view-the-downloading-videos-by-sorting-16-1srvjsc4otpwize3cqbthuvm-1-0_0.jpgFor more details, check: How to Delete Duplicate Songs
4helpful
2answers
Memory card is not working...
You should not use the memory card from other mobile to motorola. When you insert the memory card two folders will be created automatically (Sounds and images) You have to put the songs and images in the relevant folder, then only you can access. Otherwise it will display that you don't have files in the memory card.
Take a copy of all the songs and images to your pc.
Then follow these following steps
1. Format the memory card.
2. Insert the memory card to motorola
3. Transfer the files and folders to the folder(Automatically created folder)
4. Safely remove hardware
Now you can enjoy music.
Cheers...!
Mr.Maduraikaran.
Wont start
Is starter engaging but is turning the engine slowly then not turning engine? (that's what I'm reading) If so, check both connections at the block and starter. If reading proper voltage 12v or better, check voltage across battery when in "start" if it drops below 9.5v the starter has failed. (you can turn the engine by hand...correct?)
1helpful
Clarion DB365USB head unit won't play songs from 8GB flashdrive
The reading of flash drives and MP3 discs vary from each manufacturer. Usually, ten folders with music in each folder will work on most. To the best of my knowledge, Clarion reads well. When all else fails, you can always just drag and drop all the MP3's without folders. I know it's not as easy "finding" songs that are in folders but seems like you can't do that anyway.
I know this is lame, but the manual ALWAYS describes HOW to make the disc (folder trees etc.)
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Screen shows no files,but computer shows many files in mysdmx1
i figured it out!!! I hooked up the mp3 player to my computer, using the USB cord, then went to "MY COMPUTER" opened the drive where the mp3 was connected and just deleted the folder i was holding the music in, and created a new one!! i had to download all my songs over again but it worked! YAAAYYY!! it took me a month to figure it out now im kickin myself for not trying it sooner!!
2answers
I Dont know how to insert music into my player
I usually copy all my stuff to the root directory (the one that comes right after you clicked on the sansa icon in MY COMPUTER). If it still doesn't work maybe your USB port is damaged try the other one. Another option which I always recommend is to format the sansa by right clicking on its icon on MY COMPUTER and choosing Format. Let me know if it helped.
Top iRiver Audio Players & Recorders Experts
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
ExpressFiX
ExpressFiX
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
