Temp gets to 20 deg in refrigerator.
SOURCE: Dometic refrigerator freezing in bottom
Move your thermistor closer to the center. Your thermistor is attached to the fins on the inside of the fridge. Also turn off the fridge and take the circuit board cover off and make sure that the thermistor cable is plugged in. the cable is a 2 wire terminal will be on upper right or upper left of the circuit board just below the 6 pin connector.There is another possibility but remote. The cooling unit may be getting ready to stop working. Have had many customers tell me that the fridge started freezing up and a few days later quit working completely.
Hope this helps you.
SOURCE: my dometic refrigerator is not freezing properly.
If the refrigerator is 38 degrees and the freezer 18 degrees , both are not normal.
Have you used any hard and pointed object to remove any frozen food or Ice before this happen?
Have you notice any oily part coming out in the freezer or at the back of the refigerator which will indicate that there was a leak?
there are few factors that may cause your refrigerator to be like that:
1. A possible leak along with the tubing that will cause to loose the refrigerant which make the refrigerator to produce ice.
2. lost Compression (Motor compressor) this happen eventually specially the refrigerator is more than 10 years old
the best way to find out is to call a technician and have them check it
SOURCE: warm temps cause cupboard shelf above refrigerator to heat up
well thats normal mate you cannot prevent this ... perhaps try draging your fridge away from the wall so it sits about 100mm off the wall
SOURCE: Just bought a Dometic DM2862
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
