SOURCE: oven will not heat up
The oven ignitor is more than likley your problem. It has to draw a certain amount of amps to open the gas valve all the way. If it is weak it may not be doing it's job. The part number I have for this ignitor is 316030600. It's located under the flame spreader in the oven. One other thing to check is the burner itself. This would be the tube that the flames come out of. Make sure that is is not rotted or plugged. Catriver
SOURCE: Gas smell when oven turned on
CALL THE GAS COMPANY AND TELL THEM YOU SMELL GAS ... SOME GAS COMPANIES STILL COME OUT FOR FREE TO CHECK. DO NOT TELL HIM A BUNCH OF DETAILS. JUST THAT YOU SMELL GAS AT THE STOVE. CHANCES ARE YOU WILL GET A NICE GUY WHO MAY TELL YOU EXACTLY WHATS WRONG AND FIX IT. EVEN IF THEY CHARGE YOU CAN PAY THEM IN SMALL AMOUNTS EACH MOTH FOR THE BILL. 50 SECONDS IS TOO LONG ...THE 20-40 SECONDS ALLOWS FOR THE SLOW STEADY INCREASE OF GAS FLOW TO START ... TO AVOID THE GAS COMMING ON AT FULL PREASURE AND CAUSING A "HARD IGNITION" OF THE BURNERS. THE GAP AND THE CORECT DISTANCE OF THE LOCATION OF THE IGNITOR TO THE BURNERS SHOULD BE CHECKED.THIS GAP IS USUALLY IN THE SPEC. MANUAL. ALSO MAKE SURE THE FLAME SENSOR IS IN THE FLAME. FOR THE FACT YOU SAY THIS IS HAPPENING TO BOTH UPPER AND LOWER BURNERS LEAVES ME TO THINK THE GAS PRESSURE IS NOT CORRECT GOING INTO THE APPLIANCE ... THE GAS COMPANY WILL CORRECT THAT. GOOD LUCK AND BE SAFE !!!! Joe_Rex
SOURCE: Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
SOURCE: GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
