Question about Crate Cfs3
What is proper wiring from crate cfs3 3-button footswitch to crate cx130 amp
Posted by andre campbell on
tednugentlives
    New Friend:
  • 28 Answers
Its a TRS to TRS cable (stereo connectors)
Posted on May 02, 2019
2 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: I need an owner's manual
I could not find a manual for the footswitch... USUALLY the details are covered in the amp manual it is connected to... and the only issue is if the particular footswitch is compatible with a particular amp.
Posted on Sep 06, 2010
Philip Mullen
  • 4 Answers
SOURCE: Three button crate footswitch wires
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Posted on Jul 06, 2012
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp.
http://www.crateamps.com/support/index.php
Jan 28, 2014 | Crate CA30DG Taos Acoustic Guitar Amp, 30...
Got a Crate VTX 15 guitar amp, and wondering if I can use a footswitch with it?
sure, why not, the footswitch connects between the guitar and the amp, with your guitar into the footswitch, go rock that thing!
Mar 10, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
Sep 16, 2011 | Crate Cfs3
Wiring a crate 2 button footswitch to work with the prometheam ibenez bass amp...can it be done?
Mixing brands on footswitches, even within the same brand but different series is NEVER a good idea. While many can be converted by elecvtronics competent techs, the effort is usually not worth it for anything other than the simplest footswitch.
Aug 26, 2011 | Ibanez P500H Promethean Bass Amplifier...
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
I need an owner's manual for the crate cfs3 3 button footswitch
Sep 02, 2010 | Crate Cfs3
Crate Cfs3 Logo
456 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
