Question about Baby Trend Expedition Double Jogger
What is the model # for 2004 baby trend expedition le jogging stroller?
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Posted on Dec 18, 2007
Anonymous
SOURCE: stroller baby trend expedition guide manual
http://www.babytrend.com/download/2007061310319100A_Instructions.pdf
Posted on Apr 06, 2008
Anonymous
SOURCE: I'm looking for a back wheel,for a Baby Trend Expeditions -Stroller
HI,
I have the 16 inch wheels your looking for.
Just parts out a baby trend jogging stroller.
let me know if you still need them.
Thank you
Posted on Jul 30, 2008
Anonymous
  • 9 Answers
SOURCE: baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Posted on Oct 25, 2008
Anonymous
  • 105 Answers
SOURCE: Baby Trend Jogging Stroller - Need Replacement covers
they have available parts as per their website. you can visit their nearest store branch or order online
http://www.babytrend.com/products_detail.php?CategoryID=0005.0002.0000.0000&LampID=948
Posted on Apr 30, 2009
How do I adjust the seat to upright position in the Baby Trend jogging stroller?
On mine, I push the seat forward to the position I want, then there is a string behind the seat at the top with a toggle on it that I pull until it's tight and push the toggle up as close as I can to the seat to secure it in place.
Sep 02, 2009 | Baby Trend Expedition LE Jogger
On amazon for sure... take a look here Allen Sports Bike Trailers Joggers. I hope this was helpful. cheers
Mar 27, 2009 | Baby Trend Expedition LE Jogger
I just need a part
Any bike shop or better yet walmart
Nov 20, 2008 | Baby Trend Expedition Double Jogger
Baby trend expedition double jogging stroller
Aug 25, 2008 | Baby Trend Expedition Double Jogger
Contact me. I just parted out a baby trend stroller.
I have all of the wheels and any thing else that bolted to the stroller.
My email address is [email protected]
Thank you
Jun 04, 2008 | Baby Trend Expedition LE Jogger
EXPEDITION
Hi I'm looking for jogger stroller seat pls help to find and buy those seat
May 01, 2008 | Baby Trend Expedition LE Jogger
Stroller baby trend expedition guide manual
please send me an instruction manual guide for the baby trends expedition stroller
Dec 26, 2007 | Baby Trend Expedition LE Jogger
Hand Brake not functional
I checked the Baby Trend website and did not see a listing for an Expedition LE Jogger stroller. I did, however, find the Expedition LX as well as several other Expedition joggers with numbers at the end.
Here are instructions to the LX Jogger.
Here are instruction for the Standard Expedition Jogger.
Here are instructions for another version of the Expedition jogger, as well.
You should be able to use one of those to best match your stroller and make sure you have correctly assembled your stroller. Should you need further assistance, they have a customer service line at (800) 328-7363 open from 8:00am to 4:30 pm, pacific coast time.
Dec 14, 2007 | Baby Trend Expedition LE Jogger
Baby Trend Expedition Double Jogger Logo
Top Baby Trend Baby Gear Experts
Mike
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
