Goodman Manufacturing Goodman GCH950453BX 46,000 BTU 95% Gas Furnace, 2 Stage, Multi-Speed, Logo
R
Ronald Nelson Posted on Dec 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New furnace, Water In Induction Motor, Yellow Flame
Converted new furnace to propane - red springs, #55 orifice. Pressures 12.5 WC in, 6 WC low stage, 10 WC high. Took 5 turns from initial 1.5 turns to set regulator. Is this a lot? Yellow flame even with vent and flew disconnected and door open. A lot of condensation to point that there is water in induction motor. Very little air coming out of top of furnace when vent was disconnected. I assume yellow flame is from air restriction. Is excess water from poor burn or poor burn somehow result of condensation drainage? There is only a 3/4 inch hole from heat exchanger to induction motor. Is this the correct size? Seems small. Can I damage furnace using it once a day to heat house? Thank-you for the help.
Level 3:
  • Goodman Manu... Master 19,187 Answers
  • Posted on Dec 23, 2013
Level 3:
Answers
19187
Questions
0
Helped
4341755
Points
82259
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
In house temp is high and furnace stll goes on
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
The Humidifer will not reach desired humidity level
most I see have a dipole motor with an atomiser wheel on it..this takes the water and makes a mist out of it..your issue may be that the motor bearings are dry and need wd 40..the disc should turn freely if its stiff the blower will not turn.. needs oiled up..
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Vaillant turbomax vuw gb 282e hot water problem
Check for a control on the gas valve. Has this unit ever been hot? How long installed? Is it jetted for the right gas?
Model gch90703bxab
There could be other problems but check and see if your igniter is not burnt out. Ours did that and tried to ignite for two days and then I found I had to change the igniter.
2answers
Goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
1helpful
Hoover wind tunnel can the dirt cup be washed it smells horrible and I am moving to new house and dont want to stink up the house with this vacuum I hate to go out and biuy a new one as this one is on
yes you can wash the dirt container in worm soapy water,rinse off and make sure it's absolutely dry before you use it again.this link is for the manual if you need it. good luk in your new home.***
http://hoover.com/file/570/
2answers
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Top Goodman Manufacturing Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Goodman Manufacturing Air Purifier Expert? Answer questions, earn points and help others
