Set up bios to use pci-express video adapter such as NVIDA. CCTK? how to use?
Contact your PC's manufacture and ask for the proper settings or you may be able to Google search it by typing in your PC make and Model and then ask how the bios settings are supposed to be set at.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
SOURCE: VGA monitor won't work on Dell XPS210
Is the connection different. If so you need a VGA to DVI converter. You can get this at Best Buy or Fry's or any computer store.
The memory issue should not be related. Go to control panel and then to the system icon and click system is should show the memory. You can also go in to the system bios to see actually how much you have. When the system boots. It should give you an option to go to the setup screen. The screen goes by quick so you may need to reboot a couple of times.
Please rate my response.
SOURCE: Compatibility of PCI-EXpress card for Dell GX280 (Small Dextop)
So if this is a slimline pc you are kind of limited in upgrade options
space being the biggest , then being followed with cooling ability, the best advice I can give you if specs say 350 is needed i wouldn't chance having the card pull more of a load off of the PSU than what is rated for it. Hope this helps
SOURCE: Black screen with new PCI video card
We can troubleshoot it and repair it. There is no doubt of that in my mind. But now that they admitted their fault, this is the time to make them fix your computer. If everyone would do the same thing the stealing of the customer's money will be decreased by a large measure. Again, if you want us to work on it, we are ready able and willing. But the truth must be told..... Thank you for your considering us and your choice to work with our service. My name is Constantin (arzconst is an internal nickname used with the Fixya.com).
SOURCE: Optiplex 520 pci video cards Dual monitors & Vista
There is a work-around for Vista. Look here.
A little bit down you can read:
"A user could force the installation of
a XPDM driver for each of these devices, and therefore get
heterogeneous multi-adapter multi-monitor to work as in Windows XP."
If you can go that way depends mainly on the manufacturer of the video card driver.
If you are going to sell all your nice 22" monitors - let me know...;-)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
