Question about Mercedes-Benz Vehicle Parts & Accessories
High temp aralm on displays comes on on 90C with a fluate noise? please advise its a 2007 C320CDI
Temp 90C on display come with a flute noise what is it?
Posted by Hester on
Ken Walker
    New Friend:
  • 60 Answers
My friend that is your engine being very hot and crying for help, this is very serious and could cause complete engine failure. Do not start the car or attempt to drive the car it will need to be towed to your service shop. If damage hasn't already occurred the problem could be stuck thermostat,bad water pump, blown head gasket or a leak in one of the water hoses or radiator.
Posted on Jan 01, 2014
What does c 2 mean on a ls 10 dishwasher mean brand is zanussi which was bought out by Electrolux
Water temp is too high or Boiler Temp setpoint adjusted above 90C in programming
Boiler relay welded/melted
Boiler water level sensor not functioning correctly
Aug 26, 2017 | Electrolux Dishwashers
Peugeout 307 on a n plate loud knocking noise
could have something loose underneath vehicle take to an exhaust repair shop at least get a free look under neath and hopefully find the problem , could be exhaust as if that is blocked/leaking that could cause rise in eng temp as gases not escaping quickly enough
Apr 30, 2014 | 1995 Peugeot 306
High temp alarm
could be a coolant temp sensor... do you know if the car is overheating or not?
Dec 22, 2013 | Mercedes-Benz Vehicle Parts & Accessories
2007 Chevy Silverado 2500 HD. I was driving and my digital dashboard reported engine hot and AC turned off. My temperature gauge read cool. What do I need to replace?
This sounds like a bad coolant temp sensor that give computer false reading, check the coolant temp sensor connector and if it is good with no bad wires to connector then replace coolant temp sensor , when the computer gets a signal from temp sensor that engine is hot it turns fans on high speed to cool radiator and displays a/c turned off , if this truck does not have electric cooling fans then they wont run just explaining what happens depending on engine and cooling set up. replace coolant temp sensor and check connector.
Dec 25, 2012 | 2007 Chevrolet Silverado 2500HD
I have a c80 the temp shows 114 the water temp is 70.Any help?
Maybe you have a ST 60 tridata display please look after the temperature if the temp is to high change the speedsonde for ST 60 this sonde is measuring the seatemperatur an over the seatalkconection C 80 becoms the information about temp
Jul 03, 2009 | Raymarine C80 GPS Receiver
AMD temp
AMD Athlon 90C - 95C AMD Athlon64 65C - 70C AMD Athlon64 Mobile 95C - 100C AMD Athlon MP 90C - 95C AMD Athlon XP 85C - 90C AMD Duron 85C - 95C AMD Opteron 65C - 71C AMD Sempron 90C - 95C AMD K5 60C - 70C AMD K6 65C - 70C AMD K6 Mobile 80C - 85C AMD K7 Thunderbird 70C - 95C
Apr 21, 2009 | Computers & Internet
Electrolux WT-4 -- C2 error code -- What is it?
C2 is Boiler temp too high.
Possible causes include:
Hope this helps,
Kermit
Aug 20, 2008 | Electrolux Dishwashers
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Vehicle Parts & Accessories Logo
47 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
