Question about Sharp R-1610 Microwave Oven
Turntable not working
Turntable in the microwave was working intermittently, sometimes working for months then not working for months, then would start working again, but now has died again? any ideas?
Posted by John ?indley on
stargajzer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Remove the bottom cover to the oven and check to see if a rubber belt exists, if so it may have stretched and may be slipping. Replace the belt if one exists.
Posted on Dec 22, 2013
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
Turntable
The turntable motor is defective, since it is 6 months old your warranty should cover the repair or replacement of the microwave oven.
Apr 04, 2012 | Magic Chef Microwave Ovens
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microve works but turntable comes & gos
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is intermittent or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can contact Belling customer service for more help.
Jan 02, 2009 | Belling Microwave Ovens
Won't cook
check for any holes in the microwave, then also checkplugs/electrical. if ALL this doesn't work.. then you probably need a new microwave, or return the microwave to the shop, saying that it is a manufacturer fault.
Trust me, many microwaves have done this.
Apr 21, 2008 | Frigidaire PLMV168 Microwave Oven
My GE Spacesaver Microwave is "Trippin!!"
I had a similar problem and found that unplugging (or in your case leave the breaker off) for at least 12 hours then plugging it back in solved the problem.
Jan 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1610 Microwave Oven Logo
54 people viewed this question
Top Sharp Microwave Ovens Experts
Michael Thomas
Michael Thomas
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
