Question about Moultrie Video Cameras
A-5 Moultrie will not clear & delete pictures
Camera works fine, just won't clear and delete the old pictures and reset the counter.
Posted by Mary Amos on
Anonymous
YOU HAVE TO DELETE THEM ON A COMPUTER OR A VIEWER FROM MOULTIRE
Posted on Dec 27, 2013
My camera used to work just fine with my pc, now my pc won't find the camera when connected with the cord. I also can't delete pictures because the camera freezes up. I also get 'picture e
You should format the memory card, while in the camera. Find the built in utility. If the format fails (try a couple times first) then get a new memory card. Possibly this will help the conectivity issue too, if not try looking in the Disk Management section (Right click My Computer, Choose Manage) See if the camera, connected to pc, is showing there without a drive letter. Right click on it and assignn it a drive letter. Hope this helps.
Dec 07, 2012 | Polaroid i633 Digital Camera
Thumbnail photos show wrong photo, new one opens when old one is selected
Try formatting the memory card - go to the camera's menu to format the memory card.
Sep 04, 2012 | Olympus Camedia C-5060 Wide Zoom Digital...
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
How to reset picture counter numbering on Sony dsc H50... Thank You...
If it works anything like a DSC-W230 then copy all files from your camera usb stick to backup medium. then delete all files but one from the memory stick, using a usb card reader capable computer rename the one remaining file from [example] DSC00001.JPG to DSC01241.JPG, any subsequent pictures should increment properly. if you want to just reset to factory state and start from 001 again just hard reset the camera as per the owners manual instructions. Don't bother with Sony tech support on this issue, the either don't know how to do this, or are not allowed to tell you this, they told me I could not reset the numbering after my daughter did a hard reset, but I figured out it was possible to get it back to where I was at
May 20, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Can not clear memory of Vivitar 10x25 binocular camera
If you want to delete the pics just take out the batteries and the pictures are gone.
Dec 29, 2008 | Vivitar MagnaCam Binocular/ Digital Camera
Vivicam 20
I have a book. I can scan it and send it to you if you are interested. I love this camera more than my other digital. OK
Instructions to reset the photo count on the camera is basically deleting what pics are still there.
Step 1: On top of the camera is a mode button, push the button and the word All will appear.
Step 2: Press the select button until you hear 2 beeps.
Step 3: The camera will delete all pictures and the pictures and the picture counter will refresh to "0".
To Delete the last picture.
Step 1: Press mode select to LSE
Step 2: Press select until you hear 2 beeps.
The camera will delete last picture and the picture counter will show result.
Sep 28, 2008 | Vivitar ViviCam 20 Digital Camera
No pictures??
This sounds like the same problem I had. I could not find a solution without losing the photos that I had already taken. Try reseting the camera. In the menu clear all the photos out of memory. If the picture counter doesn't reset you may need to physically kill power to the camera (by pulling out the batteries) this will delete any photos in memory and reset the photo counter. Once you are sure that the memory is empty. Try taking some test photos and reconecting to the computer to see if the software sees the new photos. You may want to delete and reload the camera drivers before you connecting the camera.
Apr 25, 2008 | Vivitar MAGNACAM Binocular
Black pictures
Check your settings - could be if very black night, and you set it to 100 iso film speed, and maybe you are on say 1/1000 of sec at maybe f16, then that's ok. You would maybe need an explosion in an oil refinery to capture much.
However, you perhaps could try this:
1 change the battery for fresh one, and see if it helps - sometimes, the shutter won't really shut if battery power is very low
2. change the mode setting to auto, and see if the flash pops up and takes a pix - then if the pix is good, the camera is still working
3. Reset the camera to the factory defaults, by:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
If that fails, back to Canon! - good luck
Apr 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
PC CAM 600 showing ERR at image counter
Try reseting the camera. Here are the instructions that are taken from this Kbase article: http://us.creative.com/support/kb/article.asp?l=2&sid=2544 "Turn on the camera and then press the Snapshot button ( on the top, right hand side of camera) and the Operation Mode button simultaneously for more than two seconds. This deletes all files from the camera "
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
PC-Cam 300 no longer functions as a digital camera
Let's do a hardware reset on the player: Press Snapshot button and Operational mode button simultaneously for more than two seconds this will delete all the files from the camera. A beep sound is heard when the memory is cleared and LCD displays zero. This may get the camera working again.
Sep 12, 2005 | Creative Labs PC-Cam 300 Digital Camera
Video Cameras Logo
1,023 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
ray gallant
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
