Question about HP Pavilion A6120N PC Desktop
What processor does the board support - HP Pavilion A6120N PC Desktop
Posted by Mesegana Aschalew on
CuePC
    New Friend:
    Problem Solver:
  • 10 Answers
The Pavillion A6120N Desktop PC has a P5LP-LE (Leonite) motherboard, meaning that any of the following will work for you:
Socket type: 775
Motherboard supports the following processor upgrades:
  • Core 2 Duo E6x00
  • Core 2 Duo E4x00
  • Pentium D 9x0 Dual Core
  • Pentium D 8xx Dual Core
  • Pentium 4 6x1 series
  • Celeron D 3xx series
Posted on Dec 23, 2013
Phaser 7400 14: real time clock
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Dec 07, 2014 | Xerox Phaser 7400/DX Laser Printer
53mhz system bus processor is installed this processor is not supported on this desktop board and will run at reduced processor clock speed system performance will be impacted intel r pentium iv processor...
Determine the manufacturer and model number of the system board. Locate the system board manufacturer's website. Check for a list of supported processors for your system board. If it is on the list, you may need only to update the system board firmware. If you have questions about the suitability of the processor / system board combination - contact the system board manufacturer's tech support group or technical forums that they may be operating on the site.
Do not attempt to apply a firmware update file to any system board for which it is not intended! Doing so can cause irreparable harm to the system board.
I good luck!
Sep 04, 2012 | Intel Computers & Internet
I need the drivers for compaq processor board 2001-2002
Please give me the Model no your Compaq - Processor Board. The Drivers are avilable in HP Website.
May 17, 2011 | Compaq (169174-001) - (Refurbished)...
Mother board update
Well that can depend on a number of factors like how much you are willing to pay.
Logon to newegg.com or zipzoomfly.com and search through their motherboards for ones that match your processor. pick one that has the features you want. Im partial to Asus boards so id find one of those that would match that processor. They list which processors will work with them so it really is pretty easy. zipzoom is my personal fav.
Mar 09, 2010 | Intel Desktop Board D845BGL Motherboard
Compatible processor 3.0 HT with 845gvsr board
if the processor you have is a pin type one or rather socket 478, yes it will be o.k
Jan 21, 2009 | Intel Motherboard
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Upgrading processor
Do not know much about mac but can you change settings on M/board by using jumpers to upgrade bus speed etc or in BIOS
Aug 13, 2008 | Giga Designs G4, 1.3 GHz (5-1213c)
Plz help me out...problem in assembling AMD Athlon 64 processor in KVM800M board
There is no fix for that. You need a board that is the same as the original because that is the size of the processor. If that is a socket 462 processor, it is only designed and will only run in a motherboard with socket 462 on it. You need to either replace the processor or replace the board with the correct one.
Jul 03, 2008 | Mercury KVM800M Motherboard
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
HP Pavilion A6120N  PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
