Question about Lexar JumpDrive S73 - USB flash drive - 16 GB
Cannot format s73 jumpdrive
I have downloaded and tried to format my flash drive without success. Please help with something that actually works.
Posted by Maryka Meiring on
stargajzer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Posted on Dec 22, 2013
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
USB flash devices don't need drivers. I believe you might have removed one or both of these drives from the PC without using the proper procedure, and the PC (or notebook) is now "confused". Re-attach one or both devices, but this time, either use (Windows) Explorer to "electronicaly" eject the device (right click, then choose eject) or use "Safely Remove Device" shortcut, usually on the bottom right=hand corner of your screen (the taskbar).
Sep 11, 2017 | Lexar Media Jumpdrive S73 - Usb Flash...
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
Lexar jump drive
Its the format of your flashdrive that is not compatable with the tv. Insert the flashdrive into the computer and reformat it into a format that your tv will accept. Google which formats your tv will work with and format the flash disk to that format.
Jul 20, 2013 | Lexar 64GB JumpDrive S70 USB Flash Drive...
Can't download a 10 gb movie into 32gb lexar s73 jumpdrive. it says it's full
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Jan 28, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
REMOVE WRITE PROTECTION
Please try to use the HP USB Format Utility tool to format your USB Flash Drive.I've personally used it on even the most stubborn flashdrives.Check it out!
Download it from CNET from http://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html
Thanks and welcome.
Feb 14, 2011 | Lexar JumpDrive Classic Portable USB Data...
Jumpdrive states full but is not
File system error - format it the slow way in a different system.
Jun 15, 2010 | Lexar JumpDrive Classic Portable USB Data...
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Aug 14, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Since 2 weeks I put my Kingston 2GB flash memory in USB, Kaspersky Internet Security destroyed the software of my flash, before "KIS" it was working well without any problem but now when I put it, only see...
Hi kamalmazhar2,
If you have a U3 drive and it is the U3 software you lost then there is nothing you can do to write the U3 software back to the drive. If you would like to simply recover use of it as a storage device without the U3 software then try formatting the drive. If Windows doesn't format it successfully then search for HP Format on the Internet and try using that to format the drive.
Kingston Tech Support
May 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Lexar JumpDrive S73 - USB flash drive - 16 GB Logo
114 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Harrie
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
