Question about Frigidaire GLTF530DS Front Load Washer
Shocks broke, now drums spins freely
Washer was knocking front to back as well as side to side during tumble.  Discovered both vibration dampener shocks had broken at upper mounts.  Also, drum now spins freely by hand, even though belt is attached.  Wondering if the broken shocks is a chronic problem, and what would allow the drum to spin freely?  Is something else (e.g., speed control chip) broken??
Posted by mvamma on
  • theforce Apr 14, 2008
    Washer quit cycling correctly. Discovered both shocks broken at lower mount had allowed tub make contact with wiring on motor control breaking small black wire.
    Model LTF2940ES0
  • tjaudet829 Mar 20, 2009
    I had a broken shock upper mount. Replaced shocks and still have loud thumping or banging during spin cycle. What do I check next?
prem mathew
    President:
  • 1,294 Answers
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Posted on Mar 17, 2008
Anonymous
I had the same problem, so I purchase a vibration/shock absorber kit for $31.95, part # 134564200. This kit comes with detailed instructions on how to replace the shocks, It took me an hour to replace and was a bit challenging. It's worth it though because you will save your self close to $100.00, I know because a Frigidaire repairman quoted me $120.00 to do the job. I decided to buy the parts and take a shot at it because if it turned out I could not replace them myself, I could of hired a repairman to do it and all I would of had to pay is for labor!
Posted on Nov 22, 2008
  • erwin doebeli Feb 10, 2013
    did you replace the springs too
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Why does my washing machine shake?
FRONT LOAD OR TOP LOAD? The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Jul 24, 2014 | Whirlpool Washing Machines
During the spin cycle, the washer starts knocking
Sounds like a broken shock mount. These are usually made of plastic. if one breaks the
unit will knock. Especially true if the unit has been moved without the shipping bolts
in place from the back.
Mar 10, 2011 | GE WSXH208A Front Load Washer
HAVE A LG TROMM FRONT LOADING WASHING MACHINE THAT SHAKES WHEN SI
has one of the shocks come loose or broken. Open the back of the machine (power-off of course) and on either side of the drum there is a shock absorber. A visual check should tell you if there is a problem.
Apr 15, 2009 | LG WM-2277HW Front Load Washer
Makes knocking noises during wash cycle.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2009 | Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Vibration during spin cycle
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Frigidaire GLTF530DS Front Load Washer Logo
484 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
