This means that the ink cartridge may not be compatible or may not be installed correctly. It also may just be an issue with the printer itsel on lower end models.
If your unit is displaying E01, E02, or E03 error codes , unit needs to be repaired, please contact our Braun call center at 1 (888) 977-3578. Our representatives are available: 9:00 am – 8:00 pm (ET) Monday through Friday and Saturday 9:00 am – 5:00 pm (ET)
Error: Printer Error (3825)
Published 04/17/2012 04:30 PM ' Updated 05/30/2012 11:48 AM ' Answer ID 46577
How do I resolve the error message "Printer Error" (code 3825) on my all-in-one printer? To resolve the error:
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
FI stands for Fuel Injection. The fuel system sensors have detected a problem. It could be anything > a dirty air filter restricting airflow, a plugged injector, an error in fuel mapping, any number of things. Serious problems can trigger the computer to prevent starting until the problem is fixed. You will need to take the bike to a Kawasaki dealer to have them plug in a code reader. The code reader will tell you exactly what the problem is. Please rate my answer. Thanks.
Tools Required : • Nemesis Service suite (NSS) • Nokia PC Suite • Data cable
Steps :
1. Connect your phone in PC Suite mode 2. Open Nemesis Service suite (NSS) 3. Then click on scan for new devices button (top right hand side) 4. Click on phone info button. 5. Now Click on Scan. 6. Select Permanent Memory. 7. Click on Read.
8. It will read the permanent memory file and save it on the disk at following path. C:\Program Files\NSS\Backup\pm\<IMEI>.pm
9. Open the .pm file using Notepad. 10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there. 11. Like 5=31313131310000000000 12. Remove all “3” digit and it will be 31313131310000000000 13. 11111 is your security code. 14. Done!!
