Is it the camera within the phone that is not working? Do you have too many pictures in your phone and it cannot fit any more? If your phone is full then it will not let you take pictures. Try loading the pictures to the cloud or your pc and then restart the phone.
Using the camera:
Your phone has a flash to help you to take pictures in different
lighting environments. The flash is on by default, but you can turn it
off or use the automatic setting. To set the desired mode when using the
camera, select Options > Flash and Flash off, Flash
on or Automatic.
Fast viewing with memory card
To view your images and video clips quicker, use your memory card
as the main memory for storing them.
In the camera application, select Options > Settings
> Image / video storage > Memory card.
Capture and send
You can send the picture immediately after you have taken it when
you are previewing it. To display a picture immediately after you take
it, select Options > Settings > Image preview
time and the preview time. During the preview time, select Back
to take another picture, or Send to send the picture as a
multimedia message.
Print your images
Your phone supports Nokia XpressPrint to print images that
are in .jpg format. To print your pictures, connect your phone to a
compatible printer using a data cable or send the image by Bluetooth to a
printer supporting Bluetooth technology. Select the image you want to
print from the Gallery, and when viewing the picture, select Options
> Print.
use photobucket, it's much easier and it syncs automatically.Or you can try to take the memory card out of your phone and stick it in the laptop to do the transfer. Use a micro sd card carrier that plugs into your laptop like a regular sd card. Or you can tell your phone to always connect as a usb mass storage device.
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture. Memory card formating in camera may be not working computer or other device.
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
You can move the pictures from the phone memory to the memory card by selecting the picture and from the menu selecting Move. When clicked it will show you the options where to. Select Memory card and your picture will be moved to memory card. Initially try with one picture at a time then you can select as many pictures as you want to move.
connect the source of the picture to the computer, then save all the pictur you ever wanted, then remove the camera, then connect the cellphone to your computer, then copy those picture you save before then paste it to your folder in you phone
1-connect ur mobile with your PC.
2-open the file manager
3-then open pictures
4-now the folder which camera photos save
delete that folder
5-n make new folder n give that same name to this folder (which named folder u hv deleted)
