Question about Whirlpool LSR7333 Top Load Washer
Whirlpool model LSR7233EZO / doesn't fill fully
Washer doesn't fill completely. Cleaned and checked hoses, faucets and inlet screens. All clean and good water flow. Water fills only half way (appx. med load fill) when set on large load. How do I check fill valve and switch? My ability is above average and most tools are available.
Posted by biged55 on
  • 1 more comment
  • LC73 Jan 17, 2008
    HAVING THE SAME PROBLEM ,NOT SURE HOW TO FIX THIS
  • biged55 Feb 25, 2008
    I solved the problem by replacing the fill switch. Be certain that the tube is intact and not cracked or broken. There doesn't seem to be a reliable test for this switch, so spend the 50-60 bucks and replace it.
  • LC73 May 11, 2010
    HAS ANYONE FUGURED OUT HOW TO FIX THIS YET ?
mike kirschbaum
    Genius:
  • 1,198 Answers
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Posted on Jul 29, 2008
My washer is flashing LF
LF error code indicates that there is a water supply problem.
Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked? Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe? The drain hose may be too far inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shaped drain hose form as described in the Installation Instructions will provide the appropriate length of drain hose in the drainpipe or laundry tub.
Check it and keep us updated. remeber to rating this free answer and leave some testimonila comment.
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Code is F20, what does this mean?
Hi
Error F20 means Water Inlet Problem-no water or insufficient water supply. This issue can appear due to faulty inlet valves or due to blocked inlet hoses. Also check the filter screen at inlet valve, clean them if they are dirty. Select PAUSE/CANCEL twice to cancel the cycle. Unplug the washer or disconnect the power. Now check whether water faucets completely turned on? Make sure that the water inlet hoses are not frozen. If above things seems to be fine then you would need to replace the water inlet/fill valve.
Hope this helps... Please post back if you need more information. Daniel
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer keeps flashing F20
Hi
Daniel
Jan 23, 2011 | Washing Machines
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
When Istrted to wash my cloths , the washer stop and post F-20
This error code indicates a water supply problem.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer
Check your inlets. Close faucet, unscrew the hoses and check for any blockages, clean screens. Check faucet fully open, it should when the machine is used. Refit carefully, check for leaks. If problem still persists you should change your machine water valves at the entry.
Pl rate if helped...........
Dec 28, 2007 | Washing Machines
Whirlpool LSR7333 Top Load Washer Logo
316 people viewed this question
Marvin
Marvin
Ned Halaweh
Ned Halaweh
