Hello
From your post, I can't understand which codes do you wants. Anyway I reples to your post considering that your TV is locked and sends the procedure to unlock it. If you are in search for the unlock code, one amoung these processes will unlock your tV to factory settings, and after that you can set a parential code for it. If this isn't your need, send me a mail at
[email protected] and inform your need through mail. I'm ready andliable to help you.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
