Have replaced yellow cartridge twice hoping to fix the 093-919 y cart error message. Dell says there is a firmware upgrade to fix but printer must be error free to install upgrade. There is no tape on carts, using genuine dell etc. Any ideas?
The same thing happened to me only with the yellow cartridge. I was able to fix this problem by first turning off the printer. Then, holding down the left and right arrows, turn on the printer. Keep holding the arrows down for about 15 seconds. After that it should work. If it doesn't, try doing the same thing holding down the up and down arrow instead.
I don't have problems:))
SOURCE: my dell 3110cn printer is
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
SOURCE: what's check M cart ( error : M cart ? ) dell
Hi!
Check M cartridge is the magenta cartridge that's empty!!Replace it and you will be sorted!!
Good Luck!!
SOURCE: On my Dell 3110cn printer,
remanufactured toners, or off brand toners are sometimes not compatible. I would contact the dealer you bought the toner from and tell them the cartridge is defective and demand an exchange or refund.
