Question about Freezers
Missing Manuals I need an operators manual and spec sheet for a Beverage-Air CFG24 Freezer, please. Merry Christmas.
Posted by R Kevin Henderson on
stargajzer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Visit the manufacturer's website to download a manual.
Posted on Dec 22, 2013
2 Related Answers
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Beverage Air. Model: CFG24-1. The evaporator fan
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Posted on Jan 21, 2011
Todd B
  • 572 Answers
SOURCE: need conec of electrical system heather elemt,
http://www.beverage-air.com/Main.aspx?pid=50&tab=51 you will find the pdf files for specs & manuals here.
Posted on Aug 27, 2011
I have a double door Commercial Freezer Beverage Air, E-Series Model#EF48-1AS and is not keeping the items inside frozen. We have cleaned out the fan filters and has not seemed to help. What else can I do...
Check the fans are running ok, and the condensing area isn't too hot. Check the door closes properly and the inside isn't blocked up with ice. If all appears ok you may have to call out a technician
Aug 22, 2012 | Beverage-Air CFG24 Freezer
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
Jan 19, 2011 | Beverage-Air CFG24 Freezer
It is blowing hot air!
http://www.beverage-air.com/Main.aspx?pid=74&tab=75
I went to this web site and found several manuals on your unit. check it out.
Hope this is what you are looking for.
Be sure that the condenser on the back of the unit is clean and that the unit is not pushed back up against anything that can block air flow around the condenser.
Start there. If you need more, let me know.
May 17, 2010 | Beverage-Air Commercial Freezer...
Compressor does not kick on, low side reading just under 80 psi. compressor problem?
could be. Check out the start components first. They are cheaper and easier than a compressor replacement.
http://www.beverage-air.com/images/barEquipment/manuals/BB%20manual.pdf
try this site. It has your equipment manual and wiring diagram.
Hope this helps. Let me know if I can be of further service.
Jan 29, 2010 | Beverage-Air Freezer GF48L
Freezer motor works fine, but doesn't freeze.
  1. you probably have oil in your line.you're not suppose to plug the freezer right a way when it have been loaded on is side.you suppose to wait about 24 hours.
Jan 28, 2009 | Carrier 20.7 cu. ft. Freezer Beverage-Air...
Freezers Logo
73 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
