Question about Beverage-Air CFG24 Freezer
I need an operators manual and spec sheet for a Beverage-Air CFG24 Freezer. Can you guide in the proper direction, please?Merry Christmas
Posted by R Kevin Henderson on
Dennis Boxerman
  • Beverage-Air Master
  • 1,303 Answers
Posted on Jun 07, 2014
2 Related Answers
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Beverage Air. Model: CFG24-1. The evaporator fan
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Posted on Jan 21, 2011
Todd B
  • 572 Answers
SOURCE: need conec of electrical system heather elemt,
http://www.beverage-air.com/Main.aspx?pid=50&tab=51 you will find the pdf files for specs & manuals here.
Posted on Aug 27, 2011
Missing Manuals
Visit the manufacturer's website to download a manual.
Dec 22, 2013 | Freezers
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
I have a double door Commercial Freezer Beverage Air, E-Series Model#EF48-1AS and is not keeping the items inside frozen. We have cleaned out the fan filters and has not seemed to help. What else can I do...
Check the fans are running ok, and the condensing area isn't too hot. Check the door closes properly and the inside isn't blocked up with ice. If all appears ok you may have to call out a technician
Aug 22, 2012 | Beverage-Air CFG24 Freezer
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Freezer motor works fine, but doesn't freeze.
  1. you probably have oil in your line.you're not suppose to plug the freezer right a way when it have been loaded on is side.you suppose to wait about 24 hours.
Jan 28, 2009 | Carrier 20.7 cu. ft. Freezer Beverage-Air...
Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Jun 24, 2008 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Beverage-Air CFG24 Freezer Logo
157 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Tom Chichester
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
