I fumbled the cartridge inserting it; so, the snap side (left) won't release but the right side is hung up on the rail.
Unfortunately the only things I can say are to either try to (carefully) wrestle it out, or take it to a retail or repair shop. And they would just be doing the same thing. There's no magic answer, you just have to find a way to pull it out and try to get it lined up better next time.
SOURCE: Cannon Pixma MP500 - Waste Ink Reset
I don't belive there is a reset device for the MP500 tanks. However, when you get the empty error message, just follow the instructions about pressing OK as many times as it asks for (I think it is four time). At that point, you can continue to use the cartridges. The printer will no longer keep track of the ink level. You will have to do that yourself. But, you can continue to use the printer with all colors.
SOURCE: Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
SOURCE: i think i inserted the
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
SOURCE: Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Testimonial: "Fix worked perfectly and quick response, thanks."
