Volume is very low on unit how do you adjust it
SOURCE: DEnon AVR 2807 not giving desired output
You may be able to unplug the unit. Then turn it back on while pressing two buttons on the front of the unit. You will have to find out which two buttons they are, it can't just be any two. What you will be doing to the unit is resetting the micoprossing of the unit. When you do this the unit will flash, reset itself, you the release the buttons and your good as new. I have done this with a couple different reciever and it is a easy fix.
SOURCE: sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
SOURCE: Denon avr 1907 low volume on all chans.with the
Maybe the audio amplifier IC are fried and need to be replaced
