Hi, I just got LG DP932H DVD player. I tried all the described methods of changing the Region settings, but nothing worked out. I can't get into the Region menu. Please, help! Thanks, Joe
SOURCE: Region codes
have you tried these
Press Setup
Scroll to Lock
Press 0 (7 times)
A message will appear saying it is region free.
riz.
SOURCE: Need to play region 1 DVD in region 2
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail [email protected]
SOURCE: LG HDD DVD RH1757 region code problem
Press 'setup' on the remote
Scroll down to the 'lock' icon
Press 0 seven times - you'll get onscreen confirmation.
SOURCE: have a DV490H LG DVD player that is set to region
HELLO
I found this hack on www.videohelp.com - give it a try!
* 1. Door Tray Open
* 2. Push "000" Button
* 3. Region Code: 0
* 4. Press "Pause" Button
ALL THE BEST :-)
SOURCE: making dvd player region free
" No Disk on Display"
Press Pause on remote then enter 314159
"Display Code"
Enter 0
Enjoy!
