Insignia NS- 27" TV27 TV Logo
Lauren Austin Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv keeps saying please run auto channel scan and it won't let me connect my dish remote. what do i do?
Diana Covell
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Feb 22, 2014
Diana Covell
Expert
Level 2:
New Friend:
Answers
65
Questions
Helped
8038
Points
100
AH HAH!!! I had the same problem and FINALLY after 2 days trying to solve the program I got the solution!! Go to source on your remote and choose the proper source. When you do, don't forget to press enter on your remote as well.
1 Related Answer
MikeL DISH
MikeL DISH
  • 92 Answers
  • Posted on Mar 02, 2011
SOURCE: cant program a channel into
It's my understanding that you're trying to get your DISH remote programmed to your TV, rachellebria. The following are the steps you can take to get that accomplished:
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Hope that helps!
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
3answers
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
3helpful
2answers
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
4helpful
Viore tv won't see dish network
I will assume this is a direct connect from the wall plate to the TV. With that said you need to run a scan on the set to lock in the channel the second TV is modulated to either 60 air or 73 cable usually. Go into the menu on the tv and select the auto channel search. Some sets scan both sides at once others require you to choose cable or off air. Once this is done you should find the signal.
Let me know if you need further assistance.
Thanks for using Fix Ya.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
