After startup of the PC when using the mouse to move pointer or to click an item the screen just blacks out for a few seconds then comes back on. Using Nvidia GT 9600 Graphics cards which has TV out capability. Running refresh rate at 60 hz [frames per sec]. Connected VGA cable supplied by LG to ports on TV Monitor and Graphics card output VGA port. Is this monitor sensitive to small variations in supply voltage perhaps?
SOURCE: Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
SOURCE: connecting pc to lg 32 inche
you have not mention the model of lg 32" what i suggest is lower the resolution of your hp pc tp 800 by 600 and gradualy increase the res to get the picture which matches the plasma hope this will solve your problem
SOURCE: LG 22" TV with Geforce nVidia 5500 FX 256MB AGP card
Try getting a new video driver. Foreware = motherboard drivers and such, not video.
I saw this driver on Nvidia.com
http://www.nvidia.com/object/winxp_175.19_whql.html
Its the XP driver for those 5000 series FX cards like yours. Try installing that and checking out the Nvidia Panel after.
1680x1050 is an odd resolution for TV, that is what normal 22" monitors have but I guess it will do up to 1680x1050 only when hooked up to a PC.
SOURCE: LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
SOURCE: I'm trying to view my
I too am having the same problem. It works fine on my Samsung TV but no signal on my32lG60. If you find anything let me know. Larry [email protected]
