Coffee maker part is worn out and needs to be replaced
SOURCE: Dacor coffee maker
Welcome to the club of unhappy Dacor coffee machine owners. The problem you are having is the problem everyone has had. The only thing I can suggest that has worked most often for me is not leaving the machine on for very long. I think the temperature gets messed up if it is left on too long. I just use mine now for a few cups in the am and then I turn it off. I've been so frustrated with it that I have gone back to my french press. One of the posters on this site actually got Dacor to buy her machine back. I will probably try that route as well.She replaced it with a Meile and is very happy with it. Good luck!
SOURCE: Dacor CM24P will not dump coffee?
I had a similar problem, where the arm does not clear the 'cube'.
The issue ended up being a single screw on the bottom of the inside of the brew unit. It had come undone a bit, and needed to get tightened back down.
Check it.
SOURCE: WE NEED A PLUNGER O RING FOR THE DACOR CM24P
I picked one at my local hardware store. We have a VERY good store and that has basically everything. Take the part with you to a similar store or a bearing seal place.
