Question about Toshiba SD-5000
Can't play CD or DVD
When i put a cd or DVD the player says no disc what can i do
Posted by Lazi on
  • 2 more comments
  • Anonymous Nov 06, 2007
    my dvd or cd won't play keeps telling me there is no disc i'v tryed everything can't figure it out please help
  • Anonymous Dec 05, 2007
    when i put the disc it says no disc
  • Anonymous Jan 02, 2008
    suddenly switched and says no disc, irrespective of what disc i put in
  • Anonymous Feb 10, 2008
    Count me in...I have the same issue. I put a DVD in, get a "no" message and that's all she wrote.
    Sigh!
Anonymous
OK..I spoke to a representative at the Toshiba service center and was given the most silly procedure to follow....but IT WORKED.
Here goes:
1. Unplug the unit.
2. Remove the batteries from the remote
control
3. Press and hold each button on the remote for two seconds. Not all at was, but one at a time. Do EVERY button.
4. Put the batteries back in, plug in the unit and away she goes!!!!!!
Toshoba guessed that there is a static charge in the remote that is discharged using this method.
I know.....IT WORKED for me.
Posted on Feb 12, 2008
Anonymous
Thats dumb. your motor that turns the spindle is shot. Take the dvd player apart and replace the motor. its really easy
Posted on Jul 28, 2008
Anonymous
Thats stupid. i took mine apart... the motor that turns your disc is probably broken, thats what mine was. You need a small phillips screwdriver, a precision screwdriver kit, and a replacement motor. It is really easy to take apart.
Cd player when u put a cd in all it say loading but never play the cd
Still need help? If so, how about try this free Blu-ray/DVD/CD Player?
Leawo free Blu-ray/DVD/CD Player acts as free Blu-ray disc player, free DVD disc player, free CD player (video-CD), free HD video player (free 4K video player), free ISO file player, and free audio player (free music player). Being a free Blu-ray disc player software app, it plays Blu-ray discs for totally free, and downward compatible with DVD disc and CD discs playback, no matter they are commercial or regular. It's the best free software to play Blu-ray on Windows (including Windows Vista, XP, 7, 7, 8, 8.1, and 10).
Best Free Blu ray Player Software for Windows Leawo Free Blu ray Player
Jan 16, 2017 | The Audio Players & Recorders
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
Dvd player model dz111
there is a disc cleaner disc and a cleaning solution. put the liquid on cleaner disc and insert it.play for some time. now put a new dvd or cd and try
Oct 24, 2007 | Audio Players & Recorders
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Toshiba SD-5000 Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
