Question about Precor 9.35 Premium Series Treadmill
I have a new Precor 9.35. I notice a fan noise coming from the motor housing when I am not using it. Is this normal? Should I be switching the power off between uses? I run about every day. Thank you.
Posted by Jeff on
John
    New Friend:
  • 25 Answers
Turn off you machine always, also disconnect the treadmill remove the cover and clean the motor fan and the motor with air cans.
Posted on Dec 23, 2013
4 Related Answers
Ben Tremblay
  • 6 Answers
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
Posted on May 26, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: need a new plastic cover for the motor/electronics part.
Hi Linda
Here is a telephone # for Precor Austria +43 64 52 3900 or you may directly email [email protected].
Posted on Mar 11, 2010
Anonymous
  • 15 Answers
SOURCE: Just moved my precor c966i treadmill (we
it should be a cable that looks like an oversized telephone cable. I can't really tell by the description of the problem if you just can't remember where it plugs into or if you've lost it altogether. There will be a circuit board in the base of the treadmill that will have something that looks like a phone jack port on it. That's where it will plug into. There should only be one port on the lower board that will accept that style of plug.
Posted on Jul 09, 2010
Testimonial: "This is the exact answer to the problem--after much searching around, I finally found the little box it fit into. the treadmill is up and running. Thanks for your input."
Bestway
  • 966 Answers
SOURCE: Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Posted on Dec 13, 2013
Error 40 on precor c964i
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Feb 22, 2014 | Precor EFX 546i Elliptical Version 4
Precor usa treadmill c962i error 41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 23, 2013 | Precor C962i Treadmill 220V
Precor 9.21 and keep getting a err 40 message
see this steps and fix it. God bless you
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Oct 08, 2012 | Precor 9.21 Treadmill
Precor 9.31 stopped and error message 40 is displayed
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jun 07, 2012 | Precor 9.31 Treadmill
Precor efx 546 error 40
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 30, 2012 | Precor EFX 546i Elliptical Version 4
PRECOR EFX 546 ERROR CODE 40
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Oct 17, 2011 | Precor EFX 546i Elliptical Version 4
I have a precor treadmill 920si. I am getting error 41. I have no idea what that is. I can't find anything related to this in the handbook. Thankyou for your help.
Precor Error 41
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jul 09, 2011 | Precor 9.21 Treadmill
Precor treadmill error message 41
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 11, 2011 | Precor 9.21 Treadmill
What is error code 41 on a precor 9.21i?
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40. Precor Error 41
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 01, 2011 | Precor 9.21 Treadmill
Hitichi television will power on and than ...........
The buzzing noise would normally be either a fan or color wheel that is failing.
Jul 06, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Precor 9.35 Premium Series Treadmill Logo
316 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
Ngoro
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
