Replaced control panel, still have blinking "clean" light and I don't think it ran for a full cycle. Soap pod was still in bottom of dishwasher.
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring).
It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
SOURCE: whirpool dishwasher quiet partner 2
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
