Question about Jabra BT650 Bluetooth Headset Halo
Jabra Halo 2 turns on only when connected to power source.I think the problem should be with the battery.please help me out.
Posted by raghu vardhan reddy on
5 Related Answers
Anonymous
SOURCE: cant connect to my laptop to jabra halo headset
if it doesnt have a cord on the end you cant hook it into the laptop but if you have a cord on the end look on both sides of yuour laptop and if you see a hole but it in there if it fits
Posted on Mar 30, 2010
contest25
Harish Ramaiah
  • 124 Answers
SOURCE: i am using windows 7
Try This download n install
Hope it resolve your issue
Thanks
Harry
Posted on Apr 17, 2011
zero260b4u
Brentin Powels
  • 30 Answers
SOURCE: I need help with my
I could just write it all down, but Jabra has a nice flash User guide that have visuals. Check it out!
http://www.jabra.com/sites/mobile/na-us/products/pages/jabrahalo.aspx?tab=QSG#UID10
Posted on May 05, 2011
Jacques De Meyer
  • 500 Answers
SOURCE: The device is Jabra 650s Headset and I am trying
Hi ambahaziq,
Try here:
http://www.jabra.com/CP-CP/support/Pages/JabraPCSuite.aspx
Install the suite, it has integrated drivers that should make it possible.
Really hope it helps, I had a similar problem last year.
Kind Regards :-)
* If you found this solution helpful, please accept it
Posted on Jul 08, 2011
tjcomp
SOURCE: jabra Halo Headset doesn't turn on
It wont come but yesterday it was just working fine what do I do
Posted on Jul 31, 2011
Battery
You might be able to get one from jabra, but my suggestion would be to take it apart, find the specs, measure the dimensions and find an appropriate replacement. Or just throw it away.
Mar 26, 2014 | Jabra BT650 Bluetooth Headset Halo
Just bought jabra halo and am chagrinning it it has been 2hrs and it the red light is still flashing or is just not on at all what do l do
how long does the manual say to charge it for? usually it's several hours before you can actually have a full charge on the first use
Aug 11, 2011 | Jabra BT650 Bluetooth Headset Halo
How do I pair it with my phone? i lost the manual If I just turn it on, it my cell doesn't seem to find it. It says to put the Jabra in discovery mode. How do I do that? Also, do you know how I can...
Christine,
To put the Jabra in discovery mode, turn it on and hold the answer/end button for five seconds until the bluetooth light starts flashing and it announces "pairing mode." Then connect with your cellphone!
You can order a new charger for your car/computer from this link:
http://www.buyjabra.com/US/accessories/universal-charging-kit-car-usb-136.html
Or, for your wall from this link:
http://www.buyjabra.com/US/accessories/us-wall-charger-for-bt530-jabra-halo-144.html
Best of luck!
- Zach
Mar 05, 2011 | Jabra Cruiser InCar Speakerphone Black
Jabra BT650 won't turn on. green light blinks only while charging.
For a while I was not able to figure out how to turn the Jabra Halo headset on. What you need to do is unfold the headset and then push the hinged portion into itself, which will lock it in place so that it will no longer hinge for the time being.
Oct 14, 2010 | Jabra BT650 Bluetooth Headset Halo
I am looking to buy a wireless bluetooth stereo headset that is compatable with my Iphone 4... Any suggestions???
I personally own the Jabra Halo, Altec Lansing Backbeat, and the Motorola MotoRokr S9HD
The Jabra Halo is about 50 bucks and goes over the ear with flat speakers.
The Backbeats are about 100, and provide channeling audio via in ear plugs, but not sound isolation.
the Motorola headset is about 100 dollars, but has issues with skipping, especially if the phone is in your back pocket.
Sep 28, 2010 | Apple iPhone 4 Black Smartphone
Jabra Halo Headset doesn't turn on
Sep 04, 2010 | Jabra BT650 Bluetooth Headset Halo
Cant connect to my laptop to jabra halo headset
Mar 30, 2010 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Jabra BT650 Bluetooth Headset  Halo Logo
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
