Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
Engine won't start sat all year is there a gas filter to clean
Engine stalls with no power on acceleration. replaced injectors, fp regulator, cam shaft sensor, fuel filter, cleaned MAF. Car sat for 5 years
Could be several issues. Is the gas fresh? This newer ethanol gas goes bad FAST and if it sat for years it probably won't run the car well. Is the exhaust clear of any animal nests? What is the exact make and model of the car?
Nov 09, 2015 | Cars & Trucks
2005 Yamaha 250 Rebel will not start
If you did not put in a new battery, try that. Your old battery probably doesn't charge up enough.
Nov 04, 2012 | 2005 Yamaha Xv 250 Virago S
1999 Yamaha 1200GP Wave Runner wont' start. It has sat for about 2 years. I have new battery, new plugs and new gas, it turns over but won't start, any suggestions?
Sounds like the carbs are gummed up from the old gas sitting in them. Remove the carbs, disassemble, clean with a carb cleaner, and reassemble.
May 14, 2012 | Motorcycles
John Deere x320 not starting. Mower sat for three months. Drained and cleaned all bad gas from entire fuel system. Charged battery. Cleaned plugs and air filter. Fuel filter good. Solenoid and fuel pump...
is the primer working ? have you tried the self primer if fitted ? when you turn over the engine is the bubbles in the fuel viewer or does it just drop. or something else.
Dec 30, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Kymco 50 2009 rough idle hesitation
Check the battery.See if the gas is bad check the gas filters.Drain the gas ,have the carb cleaned.If it sat the gas is only good for 30 days.
Oct 27, 2011 | 2009 Kymco Sento 50
My mountaineer won't start. It sat for a little over a year because of transmission issues. When I finally got a trans for it, it wouldn't start. I replaced all spark plugs and replaced the...
If the engine is turning, but slow, she may need the battery terminals cleaned, if it has sat for over a year, yes, it may need a new battery. If the engine is turning over and she is not cranking up. Standard rules apply... does she have fuel? does she have spark, does she have compression? First thing is easy, get a can of starting fluid and give her a spray in the air filter area during cranking, if she pops off you have spark, which means no fuel. If it does not try to hit, that means no spark and more trouble shooting will need to be done. If it starts on starting fluid, you may have a bad fuel pump. AS gas turns to gunk as it dries up. And that may have gummed up the pump and filter. Hope this helps FixYa up.
Sep 12, 2011 | 2003 Mercury Mountaineer
Scooter sat for a year; wouldn't start; replaced battery. filled with gas. cleaned spark plug. won't start. Help
after a year sitting idle chances are that the gas inside the carb has degraded and the carb will need cleaning also when you filled the tank did you remove any old fuel? if not the its contaminated with the old gas
give it a full service new feul clean carb clean air filter then it should start
hope this helps
john
Jun 30, 2011 | Aprilia Scarabeo 50 Four Stroke...
2001 ttr 225 bike sat all last year. Would start this spring but not idle. Now it won't start. I know the carb had old gas. Where can I find a manual so I can take it apart and know what parts to...
Start by removing and cleaning the carb, it may not need any parts.
also change the oil, fit new air filter, new spark plug, and check the valve clearances
May 27, 2011 | 2002 Yamaha TT-R 225
I'm buying my friend's Goldwing 1200, 1986 FI. Bike has been garaged for 4yrs and I tried to start it with new battery but won't start but it cranks, has gas.
Check the kill switch rock it back and forth to be sure it is making contact. Open it up and spray it with contact cleaner that is safe for plastics available at radio shack. After sitting for four years I would start with the fuel system. New filter and NEW GAS and check the fuel lines for cracks and leaks. I have seen bikes that sat for 6 months and needing the carburetors cleaned and reset.
May 20, 2011 | 1986 Honda GL 1200 Aspencade Gold Wing
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
56 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
