Question about Juicers
Can;t take apart
==model 1480 how to remove top
Posted by donna readinger on
JUICE MASTER MODEL NT 9214/32597, HAS NEVER BEEN USED. I NEED INSTRUCION MANUEL.
I have home juice extractor FIRST Model No NT-9214, Nr : S 9352152.
I am very happy with it, but I damaged the plastic parts.
I'm from Slovakia, I live in the city Nitra.
For these extractor in service no longer have replacement parts.
Please help me and talk to me where can I buy these parts.
Please answer to my e-mail address [email protected]
Thank you
Sep 18, 2011 | Salton Jr. JM1 Juicer
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
Mar 15, 2010 | Jack Lalanne Power Juicer (Stainless...
How do I take apart the strainer section?
Everything should just lift up and off. May be
juice stuck together. Try a little tap to the whole
assembly.
Mar 04, 2010 | Acme 6001 Juice Extractor
I want to take it apart to clean it. How do I
You remove the top and back end. (you will need to put the silver handle down to do this) You then need the crescent tool to unhook the blade. After the blade comes out, the strainer and top level will come off with no further problem.
If for some reason you do not have the crescent tool, if there is someone to hold the strainer still, you can use two screwdrivers in the holes of the blade and press down and turn with those instead. I JUST had to do this when I realized mine came without the stinking tool!
Oct 09, 2009 | Jack Lalanne Power Juicer 250 Watts
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
113 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
