Question about American Standard 5 ft Sliding Shower Door
Unable to buy shower seal for Fresca folding shower door
I have a 4 section folding shower bath screen and need a replacement down rubber between the 3rd and 4th door please
if you can , take a section of the rubber you require to a shop that sells rubber products ( mats ,pools , mattresses rubber mouldings etc) as they have a range of rubber mouldings that may be suitable
try plumber wholesalers that sell baths , showers and toilets as they may be the agent for the manufacturer of the doors
Lastly the doors may be made by a glass fitter shop and they may have the rubber to suit the aluminium surrounds of the glass
Aug 06, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Where can i find parts for my shower door
Go to nearest home depot. They can help yo.
Oct 12, 2015 | Home
I purchased a Fresca FTL2336 Apus One-Piece toilet and installed it. I can hear a constant drip of water escaping from the tank causing the toilet to refill every few hours. I have lifted the flapper,...
The flapper may be defective or not seating completely which causes a continuing slow leak until the tank level drops low enough to cause the flush valve to refill it. I find a cheap flapper lasts just as long as more expensive ones and lasts about as long. Arbitrary replacement of the flapper is a regular periodic maintenance item
Feb 16, 2013 | Fresca FTL2336 Apus One-Piece Square...
Niagara bifold door hinges, where can i get them.?
I feel I may have the same problem and as of now I have used cable ties but if anyone knows of where I can buy this part, I shall be extremely grateful.
Jul 17, 2012 | Home
I have a Sterling 1500D Shower door and I need to replace hollow gasket at the bottom of the door. Where do I purchase this from???
It sounds like you need the sweep or seal that keeps water in the enclosure. You can buy these items, which are inexpensive and usually easy to install yourself at www.technologylk.com Technology LK carries a comprehensive range of shower door gaskets, seals and other hardware. If you have any questions about exactly what you need and how to install it, you can contact the company at [email protected] or call them at 888-663-9830.
Jul 10, 2012 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a Sterling 1500D shower door, the door has rubbed against the hollow bottom seal and ruined it- I can re adjust the door, I need the part number for the hollow seal kit.
I have the same problem. I'm doing research today, I'll keep you posted. unless you already figured out where to get the seal, please let me know.
Nov 20, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Installing a stering pivot door
on the pivot side, the seal will go toward the outside,.providing that the seal is on the door,...the seal "on the pivot side of the door" will go up against the wall jamb as you close door,.....
Jun 20, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
American Standard 5 ft Sliding Shower Door Logo
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
